CDWG: 3' listening distance?
0 Members and 1 Guest are viewing this topic. Read 2319 times.
James Romeyn
« on: 2 Dec 2005, 01:32 am »
This was B's response about the ideal RM30-CDWG listening distance:
To: [email protected]
Sent: Thursday, December 01, 2005 5:03 PM
Subject: Re: CDWG vs. listening distance?
You can sit as close as directly between the speakers, it's a 180 pattern.
B
After two auditions, both times A-B-ing w/ vs. without CDWG on two different systems & rooms, I am convinced the above statement is accurate.  I think this advantage is huge & cannot be overstated.
Can you imagine listening only 3' in front of your speakers & giving up nothing (except for possibly some low bass power)?  Can you imagine 3' providing all the integration, smoothness, impact, tactile realism, staging, & imaging that 15' prvides?  But in a speaker with the 30s dynamic envelope.  Wow!  This is unheard of except for the tinyest little minimonitor two-ways & coaxials, which for other reasons are not generally preferred by VMPS ribbon owners.
This may be just totally over the top on the 40s & RMX.
Till Brian has CDWG's available for 626R's, we must imagine the positive effects.  It should be nice.  On the other hand, if the RM30-CDWG is capable of the 626R's integration & smoothness, at the same near-field distance, that could eliminate the last & only area where the 626R may have had any advantage.
lifewithmusic
« Reply #1 on: 2 Dec 2005, 09:28 am »
Brian:
I'm just curious:  what does CDWG technology mean for car speakers?
When will there be a VMPS "inwall" for my Porsche?
thanks.
meilankev
« Reply #2 on: 2 Dec 2005, 12:42 pm »
When driving a Porsche, why would you care about speakers?  Just turn the damn audio system off, and listen to the engine.  No finer music has ever been made.
 :P
Kevin
ctviggen
« Reply #3 on: 2 Dec 2005, 01:02 pm »
If it's a 180 degree pattern, what does that do for first reflection point issues?  I assume I can still use the mirror trick to place my traps at the first reflection point.  If it really is a 180 degree pattern, I'm going to have to experiment with toe in and my current sitting position.
I don't see why the CD effect wouldn't be applicable to car speakers, but it probably depends on where the speakers are.  For instance, in my Snaab, I have rear speakers that are behind the rear seats and point upward.  I'm not sure that CD would help much, especially as these speakers are bass only.
ScottMayo
Re: CDWG: 3' listening distance?
« Reply #4 on: 2 Dec 2005, 01:26 pm »
Quote from: RibbonSpeakers.net
It's safe to say that I'm waiting very, very impatiently for the chance to try this out on an RM/x. The only complaint I have about my room is the smallish sweet spot. This is going to fix that.   :mrgreen:  :mrgreen:  :mrgreen:
woodsyi
« Reply #5 on: 2 Dec 2005, 02:08 pm »
Welcome back Scott,
It was kinda quiet while you were gone. :wink:
CornellAlum
« Reply #6 on: 2 Dec 2005, 02:20 pm »
How was that "hiatus" anyway :nono:  :lol:   Welcome back sir!
ScottMayo
« Reply #7 on: 2 Dec 2005, 02:35 pm »
Quote from: CornellAlum
Thanks! It was very peaceful. I had time for a long talk with the Sonicrock manufacturer. Unfortunately we've decided not to advertise the product here - too many doubting thomases.  :lol:
Seriously, though, I'm a reformed character. As reformed as I ever get, anyway...
