Treading on IC's
0 Members and 1 Guest are viewing this topic. Read 1495 times.
bmed
Treading on IC's
« on: 2 Dec 2005, 12:19 am »
I'm looking to run longer IC's from my preamp to amps so that I can put my preamp at my listening position (MacGyver style remote I guess?).  This would force pretty long IC's ~20ft to furthest amp if I went around the room periphery.  I was thinking of putting down a rug, and running them underneath it to the amps, which would shorten the distance by a little more than half---and save money on wire.   There is not usually much traffic across my listening room/office except me.  Now to the question----Would foot traffic put a strain on the IC's.  I've looked into a remote for my preamp, and the cost of DIYing some longer interconnects comes out cheaper.  Any thoughts?
Brad
