Powered subwoofer cable?
0 Members and 1 Guest are viewing this topic. Read 975 times.
ROB968323
« on: 1 Dec 2005, 11:50 pm »
Can anyone post experiences with different subwoofer cables?  I see that some companies such as Monster have a dedicated subwoofer cable.  Could any regular interconnects be used?  I'm curious as to why most of the better cable companies do not have a dedicated sub cable.  Any ideas which type would work best...copper, silver, etc.  My budget is around $100 - $200.
Thanks in advance.
Rob
bubba966
« Reply #1 on: 2 Dec 2005, 12:23 am »
Yes, you can use just a regular style interconnect.
If it's going to be a longer cable you might want to get one that's shielded.
I personally use an M-80 Sub Cable from Bolder Cables. They have a circle here at Audio Circle. http://www.audiocircle.com/index.php?board=11
He could build you a rather nice cable to meet whatever your needs are. And it'll fall into your price range as well unless you go for something that's waaay overkill for a sub cable.
I'd just make sure you use something that has good plugs on it (preferrably Eichmann Bullet Plugs or WBT NextGen's).
Copper or silver shouldn't matter much in a sub cable.
FWIW I used to have a fairly nice Monster Sub Cable. The cable itself was fine, but the connector's were only so-so. I had Bolder Cables put Eichmann Bullet Plugs on the sub cable I had built & it was a definite improvement. If I was doing it now I might go for NextGen's instead of the Bullet Plugs (Bullets weren't quite available back then).
Jay S
« Reply #2 on: 2 Dec 2005, 12:28 am »
I also use the M-80 as a sub cable and am happy with it.   :D
DeanSheen
« Reply #3 on: 2 Dec 2005, 02:49 am »
*caveat*     Never compared sub cables.
I use a run from Bluejeanscable.com .  Also, they will custom make you runs there for use with a Behringer 1124 Feedback destroyer.
John Casler
« Reply #4 on: 2 Dec 2005, 04:54 am »
I could be wrong, but I think a sub cable usually has 75ohms impedance as opposed to around 50ohms for a standard audio cable.
It is (to my understanding) more like a video or coax digital cable.
Maybe an expert will chime in and clarify.
Danny Richie
    • http://www.gr-research.com
« Reply #5 on: 2 Dec 2005, 04:54 am »
I have an 11' pair over in market square that I have priced really cheap.
http://www.audiocircle.com/index.php?topic=23198
JRace
  • Greetings one and Everyone!
« Reply #6 on: 9 Dec 2005, 12:53 am »
Quote from: John Casler
Nope , regular RCA's will work just fine.
And you do not need "Directional" cables.
