Duende Criatura Tube Rings
0 Members and 1 Guest are viewing this topic. Read 5361 times.
Levi
« on: 29 Nov 2005, 12:35 am »
Has anyone tried the Duende Criatura tube rings?
  • Speakers....What Speakers ?
« Reply #1 on: 29 Nov 2005, 05:47 am »
Here's an info link...... 8)
    First I've heard of them Levi. :o [/list:u]
      Did find a
short review on 6moons.......[/list:u]
Levi
« Reply #2 on: 29 Nov 2005, 05:53 am »
It looks like a DIY.  I wonder if it's worth buying.
« Reply #3 on: 29 Nov 2005, 05:54 am »
Quote from: Levi
Seems pricey..... :roll:
« Reply #4 on: 29 Nov 2005, 05:57 am »
I use these.......
Levi
« Reply #5 on: 29 Nov 2005, 06:01 am »
Thanks again Chris.  I wonder if you can hear the difference in sound.
« Reply #6 on: 29 Nov 2005, 06:07 am »
Quote from: Levi
Try them out and see if you hear a difference...or...maybe a little ring toss to pass the time.... :lol:
Gordy
« Reply #7 on: 29 Nov 2005, 06:21 am »
The Herbie's have soft contact footers to do the dampening, he uses the Teflon for clamping strength only, where the Duende's are all Teflon and look as if they would be too hard to make a good contact???  Dunno, but you can pick up Viton O rings, which are high temp and soft as well, for about 10 cents each by the bag...
BobM
« Reply #8 on: 29 Nov 2005, 01:29 pm »
Or you can replicate the Herbie's with Teflon o-rings from McMaster Carr. Dirt cheap.
Enjoy,
Bob
TheChairGuy
« Reply #9 on: 29 Nov 2005, 05:28 pm »
Levi,
The Herbie's work well (I own them).  But, before you go and spend $7.95 a pop on Herbie's...try a mortite 'hat' on your tubes.
Flatten a dime sized piece of Mortite Rope Caulk (or Dennis Rope Caulk...available thru Ace Hardware dealers) and place on top of tube, flatten it gently to tube....and allow the tip to poke thru.
It works great on the small 12ax7's and 6922's I have...dampens microphonis to a point of non-concern.  And, it's cheap - maybe $8.00 a package (that'll do probably 10,000 tubes  :) ).  I haven't used them on larger (and hotter) amp tubes...but they are great on the smaller ones.
I use the Herbies WITH the mortite 'hats' (yarmulke, if you like  :wink: )
Do not use Plast-i-Clay on them - it will melt.  But, rope caulk will not and hasn't in over 3 years using it.
Enjoy.
miklorsmith
« Reply #10 on: 29 Nov 2005, 05:35 pm »
In my Modwright CDP and pre, I find that tube rings deaden the sound too much for my taste.  Instead, I damp the chassis using Dynamat and plasti-clay (thanks, ChairDude), leaving the tubes to breathe.
Microphonics, especially prevalent in the pre before, are killed while allowing the breath of tubeliciousness to come through.
