A stuffing story
0 Members and 1 Guest are viewing this topic. Read 2945 times.
aljordan
    • Astrophotography and DRC
A stuffing story
« on: 26 Nov 2005, 08:31 pm »
Hi,
Just thought I would share my experience playing with acoustic foam inside of my 1801b.  I had originally lined all sections of the sides, top and bottom of the speakers with acoustic foam (some Black Hole 5 and some Walmart matress pad), plus the polyester batting behind the woofer.  I was always slightly bothered by a tipped up response, with a bit of harshness in a number of female vocal recordings.  The speakers also sounded thin in larger rooms.  I thought it was more related to the tweeter resistor values I had chosen.  I listened to the speakers for about a year this way.
I looked through the board here and saw Dave's recommended stuffing brew.  Not having remembered how I had stuffed the speakers, I took the woofers out and looked.  I ripped out the stuffing that didn't adhere to the recommendation, which seemed to be not quite half of that I had put in, and must say that the speakers sound quite a bit better after doing so.  I am getting more detail with mid-bass, richer bass overall, and better overall between the lower frequencies and the higher frequencies.  The slight peircing of female vocalists has been reduced as well.
Alan
pem
    • http://pemoreau.neuf.fr/speakers.html
A stuffing story
« Reply #1 on: 27 Nov 2005, 09:16 am »
Dear Alan,
I fully adhere to your experience.
I also made the "mistake" of putting too much foam. Now that I have followed Dave's recommendation, it is much better (also if it was already darn good!).
  kind regards,
  Pierre-Etienne
CornellAlum
A stuffing story
« Reply #2 on: 27 Nov 2005, 02:46 pm »
Where is the reccomendation link?  I tried fishing around the site, which is VERY iunformative FYI, but I couldn't find it.
~D
pem
A stuffing story
« Reply #3 on: 27 Nov 2005, 03:28 pm »
There is an interesting thread there: http://www.audiocircle.com/index.php?topic=10239
  regards,
  Pierre-Etienne
aljordan
A stuffing story
« Reply #4 on: 27 Nov 2005, 07:02 pm »
Quote from: pem
Dear Alan,
  kind regards,
  Pierre-Etienne
Hi Pierre-Etienne,
How are you enjoying the Jolida amp?  I was thinking of buying one, but also am considering the PrimaLuna integrated.
Thank you,
Alan
P.S.  I like your Walace & Grommit evil penguin icon.
