I have never seen that Teac in person, but have heard several modded AL700P - I own the JVC, and can verify that it has progressive scan, and component outputs too...
Stock, there is no comparison, the JVC is a superior being, with my speakers, taste, and room etc.
The Bolder modded Teac AL700P does best it for ultimate resolution and performance, but requires a more complex system - pre, power, source etc.
For me, using the Visaton b200 drivers (same as in your proposed A8 speakers) the JVC is the easier choice for me. It could be that I could tweak the Teac based system to deliver better sound, but it means MANY components, IC, etc.
Simple for me - balanced power, plus EX A1, plus DIY open baffle Visatons.
I am parked, until I see where this whole SB3 thing is going... since that could be used as a pre, and could feed the Bolder Teac directly...
Then again, Vinnie did offer to mod my JVC too, so if I open up the possibilities, they get complex in a hurry!
For my $$, I recommend the JVC - toss the stock speakers, get those A8's going, and sit back.
I suspect you will be very happy, for very limited $$.
