speaker wires inside the nuforce...
mmm
« on: 16 Nov 2005, 04:43 am »
please Jason... I don't want to bother you... but If I don't ask... i will explode...been opening putting back the cover of my amps for a dozen times....
WHAT'S THE WIRE FOR SPEAKER OuTPUTS IN NUFORCE AMPS??? WHERE CAN i GET THEM??? IF NOT AVAILABLE FOR RETAILS, MAY I PLEASE BUY THE WIRES FROM YOU??? WHAT ARE  THEY???
also I changed the input RCA wires, and your magnet wires(are they?) sound very very good!!! tight , transperant and very very real..... a bit sharp and bright thou... Is this wire the usual magnet wires from radio shack??? what size?????
thanks.......Mel
rustydoglim
    • www.nuprimeaudio.com
« Reply #1 on: 16 Nov 2005, 05:53 am »
The internal speaker wires are litz wire. Email [email protected] and tell us how much you need. If you're buying a lot, we can send you to the vendor (there are many people selling litz wire) in San Jose, CA. If you're just buying a few feet, we can do you a favor by finding some lose wires around the shop.
The input RCA wire is just standard magnet wire (thin insulated copper wire).  Not all good sounding thing has to cost a fortune.
