VMPS = CES and THE Show 2006
0 Members and 1 Guest are viewing this topic. Read 7677 times.
Brian Cheney
    • http://www.vmpsaudio.com
wave guides
« Reply #20 on: 17 Nov 2005, 04:21 am »
The wave guides work regardless of the tweeter in the speaker.
ctviggen
« Reply #21 on: 17 Nov 2005, 01:25 pm »
So, if I waveguide my RM40s, should I also waveguide my RM30C (center channel)?  Any thoughts as to toe in for waveguided speakers?  More or less than what's recommended now?
Brian Cheney
waveguides
« Reply #22 on: 17 Nov 2005, 04:01 pm »
Because of the 180 degree dispersion pattern of CD speakers, with sharp "skirts", toe-in is more critical for proper imaging, but you have better control over first reflection points because of it.
I use some toe-in, but less than before, in my system and LEDE room with the wave guides on.
As John Casler reported, we have begun using the Blackhole 5 in most cabinets and it has improved performance top to bottom.  This is the best $22 per sheet (plus shipping) you'll ever spend..
RoadTripper
PRs
« Reply #23 on: 17 Nov 2005, 04:12 pm »
Two questions: Will the new PRs be of the vitrified sort? And how soon can orders be made?  Thanks.
Brian Cheney
wave guides
« Reply #24 on: 17 Nov 2005, 04:46 pm »
All passive radiators are vitrified nowadays.
Give us a short time and we'll announce availability of the CD upgrades.
kckucera
    • http://www.hcdsi.com
Here is Xtreme's URL
« Reply #25 on: 18 Nov 2005, 03:04 pm »
The other day I got the Xtreme Cables ICs and swapped out the ones I'd been using
It took me a few minutes to find their URL so here it is for those of you that are as google impaired as I am.
http://www.xtremecables.com/
CornellAlum
Re: waveguides
« Reply #26 on: 18 Nov 2005, 03:06 pm »
Quote from: Brian Cheney
I couldn't agree more!!!!!!!!
D~
koteng
Re: waveguides
« Reply #27 on: 19 Nov 2005, 09:24 am »
Can Blackhole 5 sheets be ordered from VMPS together with other upgrades such as the CD?
Roger
Brian Cheney
bh5
« Reply #28 on: 19 Nov 2005, 03:26 pm »
Yes.   Two sheets are enough for most cabinets, allow 3-4 sheets for the RM 40.
John Casler
Re: waveguides
« Reply #29 on: 19 Nov 2005, 04:53 pm »
Quote from: koteng
Roger  ...
Hi Roger,
Current pricing for the SR-71 upgrade, and Black Hole 5 sheets, is listed on the VMPS Price List Sticky
http://www.audiocircle.com/index.php?topic=10799
James Romeyn
« Reply #30 on: 20 Nov 2005, 07:07 am »
Apologies if wrong...It may be incomplete to state the purpose of the new passive radiators (with the CDWG) is to match the lower overall output resulting from the CDWG slot.  The lower overall mid & treble output can be corrected by simply turning the level controls up about 1.5dB.
There is a secondary effect of the slot.  At 20 kHz, the CDWG increases the dispersion to 180-degrees, & a 6 dB/octave low-pass filter effect is introduced with a 10 kHz pole.
A classic treble control (remember those?) boosts or cuts 6 dB/octave at 10 kHz.  Turning up such a control will correct the CDWG treble rolloff.  Important note: Digital treble controls in modern components are bypassed in "direct" & pure analog modes (phono, SACD, DVD-A, etc.).
Barring a treble control, a less accurate but practical solution is to increase the speaker's bass Q.  This will make the the bass curve above the cutoff peak look like it was high-pass filtered, thus balancing & complementing the CDWG low-pass filter effect in the treble.
Probably the PR Q is increased via stiffer spider &/or surround, providing quicker response & less overhang than simply adding more mass.
John Casler
SR-71 Upgrades now listed on "price sticky"
« Reply #31 on: 20 Nov 2005, 07:24 pm »
Many have called or posted to get the pricing on the the SR-71 upgrade option for various cabinets.
Also sheets of BH5 are available and a chart listing the "sheets per cabinet" is shown too.
At this point it is as follows:
SR-71 cabinet insulation package:
RM/x = $550
RM40 = $480
RM30 = $240
RM2 = $250
626R = $150
All Subs = $98
LRC = $88
Black Hole 5 = $22 a sheet (18"x12")
Suggested sheets for the following speakers (sheets per cabinet)
RM 40 (4)
RM 30 (2)
RM 2 (2)
626 (1/2)
Subwoofer (any) 2
RM1a (2)
LRC (1)
gongos
« Reply #32 on: 20 Nov 2005, 07:30 pm »
Are there instructions for how to apply the BH w/o sending the speakers in?
John Casler
« Reply #33 on: 21 Nov 2005, 11:03 pm »
Quote from: gongos
BlackHole 5 has a "self adhesive" that allows you to "cut and paste" it into the cabinet.
Maybe Brian can offer the most strategic placement.
