Sony's new ES Line All-In-One (Digital Power)
0 Members and 1 Guest are viewing this topic. Read 106732 times.
Brad V
« Reply #220 on: 24 Sep 2003, 03:02 pm »
Quote from: JackStraw
I picked up a AVD-C70ES... I was very pleased with the purchase until I tried to play a DVD last night (first time). Both audio and video have a "hitch" to them, sort of a hesitation like the DVD is scratched. Maybe the HT nuts in here can tell me what the term is for this. I tried two different DVDs with the same results. This hasn't happened on CDs at all. Has anybody else noticed anything like this? I figure there must be a problem in the transport or decoding circuitry.
I'd really like to get one of  ...
Well, I haven't seen a DVD Player that didn't hesitate for a long time on DVD's. It has to read in all that information, so to build the selection menu. I've heard that the Esoteric DV-50 is very fast at this, however my Toshiba DVD Player, usually takes about 45 seconds or more, before I can even select a menu option.
Hope that helps,
Brad
JackStraw
« Reply #221 on: 24 Sep 2003, 03:11 pm »
Quote from: Brad V
Hope that helps,
Brad
It's not a hesitation before the menu comes up. The picture freezes and the audio drops out during playback. It's definitely not normal -- you can't watch a movie like this.
Oade is cool about it, by the way, if I don't want to deal with Sony service I can return it for credit toward the new unit. I need to do some more research.
kendrid
« Reply #222 on: 24 Sep 2003, 03:59 pm »
I received my 3000ES yesterday.  Summary: so far with 2 channel is sounds incredible.  It is very smooth, detailed, the soundstage is wide and has pinpoint accuracy.
I did not A/B compare it to my Jolida 1501RC yet, but it will be interesting.
A detailed post is here: http://www.avsforum.com/avs-vb/showthread.php?s=&postid=2712235#post2712235
Thump553
« Reply #223 on: 24 Sep 2003, 04:10 pm »
Are you talking about a hesitation every time the DVD changes chapters?  I had a cheapie ($200) early generation DVD player that did that-it also had a lot of trouble reading certain discs.  After a year or so it did an unlamented death.
If that's the problem, I'm guessing its a problem with the DVD transport mechanism, which should be curable under the warranty.
_scotty_
« Reply #224 on: 24 Sep 2003, 04:30 pm »
Quote from: kendrid
kendrid, are these preliminary results based on a direct digital feed into the receiver or is this an analogue signal for an input.
Inquring minds want to know.     Scotty
JackStraw
« Reply #225 on: 24 Sep 2003, 04:54 pm »
Quote from: Thump553
The hesitation isn't during chapter changes, it's just throughout playback. We're talking about repeated picture freezing and audio dropout.  It was so bad that we only made it through about 15 seconds of playback.
I'd feel better about the conclusion that it's the DVD transport if there were also CD playback issues, but there aren't. Anyway, it's definitely under warranty and Oade is willing to do a refund. I'm pondering -- I'm not wild about the prospect of repair for fear that the problem will return later.
enzo
« Reply #226 on: 24 Sep 2003, 05:04 pm »
   Scotty
He mentioned using the optical (digital) out from his 400-cd player.
kendrid
« Reply #227 on: 24 Sep 2003, 05:17 pm »
Quote from: _scotty_
Quote from: kendrid
These were from my 400 disc changer via optical.  I did not try my Music Hall CD25 via analog or optical yet.  I use my 400 disc changer as a place to keep my CDs.  I figured with the digital processing inside of the 3000ES I would try the POS 400 disc changer.  It sound incredibly good.  I am hoping that Friday night I will get to A/B against my Jolida.  I have a switch box to change between the two and I might even be so anal as to use a voltmeter to set the volume levels (instead of a SPL meter).
_scotty_
« Reply #228 on: 24 Sep 2003, 05:28 pm »
Quote from: kendrid
These were from my 400 disc changer via optical.  I did not try my Music Hall CD25 via analog or optical yet.  I use my 400 disc changer as a place to keep my CDs.  I figured with the digital processing inside of the 3000ES I would try the POS 400 disc changer.  It sound incredibly good.  I am hoping that Friday night I will get to A/B against my Jolida.  I have a switch box to change between the two and I might even be so anal as to use a voltmeter to set the volume levels.
Flame Suit On! I wouldn't want to take any bets against the SONY at this point. Especially after it was fully broken in.This should be an Interesting
comparision as Jolida's have a reputation for good sound.
            Have fun,Scotty
kendrid
« Reply #229 on: 24 Sep 2003, 05:39 pm »
            Have fun,Scotty
I am not expecting miracles from the Sony, but I was very, very happy with what I heard last night.  I actually dislike Sony in ways.  Most of their audio equipment is garbage that people buy just because 'It's a Sony!"
I have had a LOT of receivers in my system in the past year.  I guess you could say I have been looking for the "holy grail" receiver that does HT and can still do music well.  I purchased the Jolida 3 months ago, so obviously I haven't found that magic product yet.  I pretty much gave up until this new Sony came along.
I have had:
Denon 3803, Elite 45TX, NAD T752 (sound great, but died a quick death), Rotel 1055 (very good, but had an issue with optical inputs from my satellite receivers), Yamaha 1400 (purchased one week ago).  The Yamaha is my current receiver, and it is great for HT.  If the Sony does not work out, my system will remain the Jolida and Yamaha.
TheeeChosenOne
« Reply #230 on: 24 Sep 2003, 08:21 pm »
If I read correctly your problem, I had a similar issue with a Phillips SACD 1000 where, for no reason whatsoever, the picture/audio would freeze for about 1-2 seconds during DVD playback.  This would happen only ONCE per movie and between chapters of scenes, usually towards the end of the movie.  I had to send the Phillips in for repair.  I also bought the Phillips SACD 1000 at Oade..............I always frazzle and wonder about how ground shipping electronic products can do damage in some form or other.
As for my Sony C70 ES, I have never had one issue with it (i.e. no picture freezing).  It has been bullet proof through lots of movies and loud music.  :)  What a machine!!
What I recommend is to see if OADE can exchange your unit OR give you credit for 2 way shipping and credit towards the new upcoming units.
As a user of many Sony ES products over the years, I have always had great experiences with reliability and performance.  I'm sorry to hear when a person has a lemon with any brand or model, but that is the crapshoot with electronics of all sorts these days.......Plus the frazzling shipping!  Have you ever seen UPS guys handle stuff in their warehouse?  :o  :o   :o
Good luck in getting your problem resolved!
audiojerry
« Reply #231 on: 24 Sep 2003, 09:59 pm »
I promised a review. For those of you interested in my take, here it is:
http://www.audiocircle.com/index.php?topic=4907
If you don't feel like reading it, then this is my suggestion:
BUY IT!
BUY IT!
BUY IT!
 :D :!:
TheeeChosenOne
« Reply #232 on: 24 Sep 2003, 10:46 pm »
Audiojerry,
Good review.  I concur with your statements.  Keep in mind the unit keeps on breaking-in well over 150+ hrs (to be conservative).  The sound is truly fantastic.
There is indeed a paradigm shift taking place.   :D
For those sitting on the fence, I would suggest to make up your mind soon.  These units are at AMAZING price at this moment and are being discounted by retailers to make room for the new models.
The pricing doesn't get any better than this folks.  I paid $750 for my C70ES way back when.  Even at $1000, it's an absolute steal.
_scotty_
« Reply #233 on: 24 Sep 2003, 11:03 pm »
Quote from: audiojerry
BUY IT!
Dear audiogerry,I think I have the Missing ingredient to put the SONY over the edge performance wise.Purchase a set of Daruma vibration isolation devices and place them under the SONY.If the SONY is a really hi accuracy very transparent window into the music the transport
will tell you when micro vibrations from the outside world are making it unhappy by rewarding you with way better sonic performance when the amplitude of the offending vibrations are reduced.The Darumas are very
effective as isolating the device placed on top of them from horizontally
propagated vibrations.They are about $100.00 from http://www.musicdirect.com/ .
AphileEarlyAdopter
« Reply #234 on: 25 Sep 2003, 12:38 am »
Also, adding an IEC outlet and after-market power cord will make quite a difference..man..you guys are getting me excited..I am waiting for the 500 or 700ES or the DA3000ES receiver.
BTW, audiojerry, did you connect this to a power conditioner or not ? Did you test with any analog inputs ?
Dmason
AVD vs STR?
« Reply #235 on: 25 Sep 2003, 01:02 am »
Anyone out there who has studied the nature of the S-Master Pro upgrade and Direct Digital concepts have any thoughts on the relative merits of a receiver, using coaxial digital input, and opting for quite abit more power/better PSU at about the same price, versus the AVD? A receiver would have a little LESS going on in there, although the sacred signal path would be somewhat compromised; then again, it is artfully handled by the amp architecture. Hmmmm...Something to consider....Let's have some opinions on this. I want to make a decision which one to sport for.
Note: The AVD and DA/DB series are beginning to hit the streets in the UK and EU right NOW!!!
sharper
Re: AVD vs STR?
« Reply #236 on: 25 Sep 2003, 01:21 am »
Quote from: Dmason
Has anyone found any pictures of the back panel of either the 500ES or the 700ES, yet?  I want to see if there are any new features compared to the 50 & 70.
I just searched for AVD-C700ES and S500ES on Google after reading Dmason's post but didn't find any new links.
randytsuch
Re: AVD vs STR?
« Reply #237 on: 25 Sep 2003, 01:32 am »
Quote from: Dmason
Anyone out there who has studied the nature of the S-Master Pro upgrade and Direct Digital concepts have any thoughts on the relative merits of a receiver, using coaxial digital input, and opting for quite abit more power/better PSU at about the same price, versus the AVD? A receiver would have a little LESS going on in there, although the sacred signal path would be somewhat compromised; then again, it is artfully handled by the amp architecture. Hmmmm...Something to consider....Let's have some opinions on ...
I think whenever you talk about a two box solution, jitter becomes an issue.  Since everything is in the same box in the Sony, jitter in it should be VERY small, if they did it right.
I am waiting for the Sony Pro stuff to come out, so Ric can tweak it, and then I can find out how good this can really be.
Randy
TheeeChosenOne
Pics
« Reply #238 on: 25 Sep 2003, 01:34 am »
Quote from: sharper
Has anyone found any pictures of the back panel of either the 500ES or the 700ES, yet?  I want to see if there are any new features compared to the 50 & 70..........I just searched for AVD-C700ES and S500ES on Google after reading Dmason's post but didn't find any new links.
I've only seen pics of the fronts:
http://news.sel.sony.com/digitalimages/album?album_id=144098&page=1
SONY AVD-C700ES
SONY AVD-S500ES
sfdoddsy
« Reply #239 on: 25 Sep 2003, 02:34 am »
I suppose it would be futile to hope that there's a set of 5.1 inputs and a full set of preouts hidden in the back somewhere?
