Signal Splitting 3 times for 3 subs ?
0 Members and 1 Guest are viewing this topic. Read 1647 times.
oris98
« on: 13 Nov 2005, 07:35 pm »
Hi all,
I have just acquired 2 Force subs and would like to use them in addition to my 2 ch setup.   I have an other 12" HT subwoofer for movie only.  Now with these 2 Force, I would like to use it for HT as well.
My question is can I have the signal from my Denon 2802 LFE out split 3 times for each sub with 2 F or Y RCA splitters ?.  Would there be any issue going with this approach ?
Many thanks in advance..
bubba966
« Reply #1 on: 13 Nov 2005, 09:40 pm »
You should call up Bolder Cables and ask Wayne about making you a custom sub cable for your application that eliminates all of the Y-Splitters. I had him build one for me that took the single LFE out & "split" it to 4 plugs. I'd been using 3 Y's to split the signal before. And now there's no additional connectors as the Y's were taken out of the equation and it's a one piece cable instead of 4 cables w/3 Y's.
And I'd like to say that my new cable is a lot nicer than the old setup I was using. It was more than worth it to get the cleaner, tighter bass that I have now over the old cable setup.
Mike Dzurko
« Reply #2 on: 14 Nov 2005, 02:49 pm »
Oris98:
Bubba966's idea of a custom cable is a good one. Multiple DH Labs Y-adapters will also work well, I've set them up many times that way and so have many of our customers.
Groch
« Reply #3 on: 15 Nov 2005, 01:47 am »
OK You's smart guys.  You have established that it can be done, but should it be done?
If you had 3 subs on one system would you hook them all up on LFE?   Wouldn't there be a benefit in terms of balence and versatility to have one or more of the subs connected through a standard pre-out?    I thought that LFE information was spotty on a lot of disks.   Would he be better off setting the "main" speakers to "large" and throwing a sub in there?
George.... groovin to Kate Bushes first new CD in 10 years on Sapphire XLs.
