System matching must also be considered. Reportedly the Sonic Impact variants don't like low impedance/low efficiency speakers. My experience with the Clari-T is that it clips very "softly" (continuing to turn up the volume "too much" has almost no effect).
With my 89 dB/w/m, 8 ohm, 30 - 20,000 Hz, very amp friendly single driver speakers (Bob Brines FTA-2000) I'm definitely not suffering with my 6 wpc Clari-T amp, but the extra 8 dB of gain that Teac offered blew me away. Hearing the difference was an epathany and would have been to anyone close to being called an audiophile. Many musical forms don't have enough dynamic range and some speakers just don't have power handling/dynamic capabilities to take advantage of additional power. This is particularily true of low efficiency designs, such as those with small sealed cabinets. My speakers are large transmission line designs and being single driver based, are by default active designs with the advantages of direct driver/amp connection. So they should be able to take full advantage of extra power. The NuForce amps would provide an additional 8 dB of gain over the Teacs, but their cost is also significantly higher too and cannot be modded for battery powered use.
Listening levels do introduce lots of variables, but the marketing hype behind "needing" huge amps and extreme spls grinds me. Most of the time folks are listening with less than 1 wpc. Similar to cars, most of the time folks are only using 25 horsepower or less, yet there are times when additioned horsepower is needed (more often wanted). For audio, my goal is around 100 dB, for cars about 20 pounds/hp.
I prefer to rate amps in terms of decibels of gain, not watts as that is what we hear (and isn't that the bottom line anyway?). So 1 wpc is 0 dB of gain (that's what the speaker efficiency rating is based on). Every doubling of power adds 3 dB of gain (sounding half again as loud) and every tenfold increase in watts adds 10 dB of gain (sounding twice as loud). So a 600 wpc amp can play twice as loud as a 60 wpc amp and 4 times as loud as my little 6 wpc Clari-T. So obviously speaker efficiency can make more of a difference than wattage ratings. And the difference between 40 and 50 or 80 and 100 wpc is only 1 dB (the smallest incremental difference in volume that can be humanly preceived), so we can get over those small differences too.
