Complete 2-Ch Hypex Amp Kits $495
0 Members and 1 Guest are viewing this topic. Read 27543 times.
Kevin Haskins
« on: 10 Nov 2005, 12:33 am »
Ok.. for you bargain hunters who are willing to break out the soldering iron & provide a little free labor we are now offering the basic 2-channel Hypex amplifier kits.
The UCD-180 versions are now on the site and I'm working on the UCD-400 version next.
Hypex Amplifier Kit
kfr01
Great looking kit!
« Reply #1 on: 10 Nov 2005, 01:10 am »
Kevin:
Looks like another bang for the buck diy solution!
kfr
Kevin Haskins
« Reply #2 on: 10 Nov 2005, 01:28 am »
Yea... that price is for the basic UCD-180ST & standard supply.   Most people are going to want to trick them out so the average price will probably be higher.
If I where going to build one for myself I'd use the Softstart, UCD-180AD & the HG power supply which would tip the scales at $750 but you end up with a KILLER amp for that price.
If you need more power the UCD-400 version is probably going to start off about $775 for the basic kit which will include the HG (high grade) power supply.   The HG supply doesn't really cost any more for the UCD400s because you would need two of the standard supplies to run a UCD-400 build anyway.
JoshK
« Reply #3 on: 10 Nov 2005, 01:37 am »
I'm curious why you would say the softstart.  Is it because you use a heck of lot of capacitance?  I don't get turn on thump even with my UcD400s, 2x 600watt toroids, & ~35-40kuF of capacitance.
MrCool78
Congrats Kevin
« Reply #4 on: 10 Nov 2005, 04:07 pm »
G'day...Kev
I've been searching amp for 2 months I reckon Hypex amp will be the best  amp in the market, I hope I can end up my last hunting with hypex.
Before that I got some questions about this hypex amp.
1) what is the difference between AD and ST version in sound quality?
2) is that possible to replace the caps on UCD power supply? for ex with blackgate or rubycon?
3) does the chassis fit for 2 channels dual mono configurations? 2 channels, 2 power supplies and 2 transformers?
4) what is the benefit using RFI/DC filter?
5) I'm from Australia is it possible to use 240 VAC transformer?
Sorry for giving you heap questions, btw if hypex amp doesn't has problems using some of the best parts to be installed in hypex amp I'm glad to upgrade it
For UCD amp 180 AD ST 2 channels
1) Using plitron transformers
2) Using all with Blackgate caps
3) Using UCD HG power supply
4) Using all wiring with Cardas
5) Using WBT binding posts and WBT RCA inputs
That's all I thougt.
2 thumbs up for your good work Kev
Thanks a lot
JoshK
« Reply #5 on: 10 Nov 2005, 04:15 pm »
Blackgates of appropriate size would be atrociously expensive!  Something on the order of $200 each and you'd need ~4 of them for a stereo amp.  This is why people don't use BG in amps, only preamps and sources.  My suggestion is to look to Nichicon KG Golds for hiend at a sane price, or if you can track them down, Siemen (now under another name) Sikorel Slitfoils are highly bespoke.
Kevin Haskins
« Reply #6 on: 10 Nov 2005, 04:30 pm »
Quote from: JoshK
The softstart doesn't control turn-on thump.   It's there mainly so that you don't pop low value fuses during turn-on.    The Hypex power supply has a feature that controls the turn-on/off noises via the mute function on the modules.
The benefits of using a softstart:
1.  As said...  you can use a lower value mains fuse.
2.  You save wear/tear on the mains switch.
3.  You don't slam the rectifier & mains caps with a large turn-on current.   Prolongs life of those components.
The other nice feature the Hypex unit has is that you can use a switch to control the standby feature on the Hypex modules.   That allows you to keep the amp in standby mode rather than full shut down.
There is also a feature to allow you to use a thermistor on the heatsink of the amps to shut them down under overheating conditions.   It's just another safety device.
Overall... if I where to build one for myself I'd use a softstart.   You can get by without it by using a thermistor on one leg of the primary which puts a 2 Ohm resistance on the primary until the power switch is flipped.   The current going through the thermistor lowers the resistance value when it's on.   We have used that approach and get by with an 8A fuse on 800VA transformers with 80,000uF of capacitance in the supply.
Kevin Haskins
Re: Congrats Kevin
« Reply #7 on: 10 Nov 2005, 04:43 pm »
Quote from: MrCool78
G'day...Kev
Not a lot.   The ST version is pretty good.   The AD version is a little more transparent giving a slight nod to lower level detail in the recording.
As stated... the Blackgates would be cost prohibitive.   You can try switching any caps you like into the power supply.   Just make sure they are of the appropriate voltage rating.   I've tried the Panasonic, BC (on Standard supply) and the Slit-foil (on the HG supply) and there are sonic differences but they are subtle ones.  It's hard to comment on what is best without taking it within the context of a given system and a person's taste.
There is plenty of room in the chassis but all of these questions depend on which transformer & which power supply you choose.   You could fit two 250VA transformers, and two ST supplies.   The HG supply is larger but I think you could make it fit.    I'm not convinced there is much of an advantage to using the dual mono supply.   I hear very little difference between the stereo and dual mono configuration.
You filter RFI & DC from the mains line.   The DC filter 99.9% of the time does nothing because you need a lot of DC on the mains to saturate the torroid.    RFI levels on the mains varies from location to location.
The standard transformer has dual 115VAC primaries so you could wire it for 230V use.   All the Hypex equipment that goes on the mains (softstart) are 230V rated.
I'm not sure how much benefit you will get over upgrading from the AD version with the Hypex HG supply.   You could easily spend multiples of the base price on the upgrades you have mentioned.   I'd say build it stock first and make "improvements" one at a time to see if they make an audible difference.   Often they don't.
kenk
« Reply #8 on: 10 Nov 2005, 05:11 pm »
Hi Kevin,
Is this amp sensitive to cable and grounding?  I have used digital amps before and they all had hissing sound one way or another.
Ken
Kevin Haskins
« Reply #9 on: 10 Nov 2005, 05:42 pm »
Quote from: kenk
Hi Kevin,
Ken
The Hypex units are stone dead quite, no noise hiss or hum nor any of the whistling you hear from your other digital amps.   This noise is typically related to the switching frequency.   We had a lot of problems with the LC Audio units in this regard.   I've had none with the Hypex units even when sticking seven in one chassis.
They also have no problem with radiated RFI like virtually all other digital amps.   I can leave the top off the amplifier and run an FM radio within inches of the unshielded amplifier modules without interference.
There are several forms of noise that can cause problems in amps.   I've yet to build one where there was any audible noise from the speaker during operation.   Only during shut down, and then only if you don't use the Hypex power supply do you get any noise.   With the Hypex power supply there is no noise during power up/down cycles due to the toggling of  the mute function.   If you build your own supply you will get some power up/down noise as the power supply rails drop or raise.
You CAN still manage to get a system ground loop.   This is pretty much the case with any amplifier, digitial or not, so its more of a system grounding issue rather than a design issue with the amps.   Also you should use good wiring technique inside the amp (keeping power away from signal lines, twisting AC power etc..) but those are normal layout issues you have with any piece of equipment.   The Hypex are no more or less immune to layout problems with the exception of perhaps using the balanced inputs, which gives you better noise rejection characteristics than a single ended input will.
Kevin Haskins
« Reply #10 on: 10 Nov 2005, 05:50 pm »
Here is a picture of all the components included in the base kit.  The top cover and the front panel are not shown in the picture.
Here is a picture with the HG Supply and softstart.    You could run a second torroid and power supply for dual mono operation without too much trouble.   The transformer is about $60 & the power supply $85 for the ST version and $195 for the HG.   I'd say the only way it would make sense is if you used the HG version so you would be adding about $255 to the price of the upgraded HG kit for a true dual mono version.
pacifico
« Reply #11 on: 11 Nov 2005, 02:21 pm »
how does the amp do with single driver, high efficiency speakers?
bikes and beats
Awesome!
« Reply #12 on: 11 Nov 2005, 03:36 pm »
That looks like the FIRST amp kit I'd EVER consider!
Congratulations.
So how much heat does this puppy pump out?
It would be sweet to have my brother carve me up at least a wooden face plate, maybe sides, too.
Any problem with that?
-Mike
dhiebert
    • http://darrenhiebert.com
Big case
« Reply #13 on: 11 Nov 2005, 03:55 pm »
So why is the case so big? It looks like it could be half the width and shorter in depth.
Darren
Kevin Haskins
« Reply #14 on: 11 Nov 2005, 04:26 pm »
Quote from: pacifico
I've used it with the FR-125, which fits the single driver category... not the high efficiency part.  ;-)
The main concern with high efficiency speakers is noise.   In that regard the Hypex amps are going to be significantly quieter than any tube amp I've used.    There is zero noise unless you have some sort of ground loop in your system so they would be a perfect match in that regard.
The main thing most single driver advocates seem to look for is the low-level detail retrieval and the midrange magic that lopping off the frequency extremes brings to the forefront.     The low-level detail retrieval is there is spades on these amplifiers.  The midrange lusciousness of let's say a 300B SET isn't there to the same magnitude but it's in evidence if the recording has it and the amplifiers sound more faithful to the source than most high distortion amps that introduce a heavy dose of 2nd harmonic.
I personally like a little of that 2nd harmonic so using a tube preamp to season my system is how I achieve it.
Another characteristic that differs from let’s say a single ended 300B amplifier (my frame of reference because I own a pair), is that as you turn it up the 300Bs compress considerably on all but very high efficiency speakers (>100db/1W/1M).   They don’t sound nasty in compression but they audibly compress compared to the Hypex amps.   The magnitude depends on the speaker.   As expected the higher power pays off with dynamic passages and louder listening levels.
Kevin Haskins
Re: Awesome!
« Reply #15 on: 11 Nov 2005, 04:34 pm »
Quote from: bikes and beats
Congratulations.
-Mike
Thanks.... I really didn't do much.  Bruno Putzeys is the man.   He designed the modules and I must say did an excellent job.   There is nothing I'd change at this point which is one of the VERY few times I've felt that about a design.
There is very little heat in the UCD-180 modules.   The case is the heatsink in this 2-channel set-up and it never even gets warm to the touch.   If you use the standby mode of the amps there would only be a couple watts of heat dissipated under idle.   The amps are >90% efficient so they run COOL.
There is no problem with the wood front.   The front goes on with eight (or four if you choose) screws and it's flat so doing a custom front is very easy.    The sides would take a little more creativity.   You would need to screw the wood to the side as it provides some structural support.
Kevin Haskins
Re: Big case
« Reply #16 on: 11 Nov 2005, 04:43 pm »
Quote from: dhiebert
Darren
It could for the 2-channel kit.   We use the same chassis to build up to seven channel amps though so we would have to stock another chassis, which I'm hesitant to do.  :-)
I like standards also.... the chassis is a standard 2-U size to fit a standard equipment rack and it fits in a predictable manner in most hifi cabinets.   Small chassis also are a pain in that they often don't have enough weight to keep them planted when using massive power cords, speaker cables and interconnects.   It actually helps in my experience to have some heft to the chassis.   Also... as you stuff these things with much larger transformers (upcoming UCD400 & UCD700 kits) you need a substantial chassis to securely mount the transformer.    If you use a switching power supply that isn't as much of a concern but with a linear supply the weight adds up quick.   Better to have an overbuilt chassis with extra room than an under built one with little room to work.    Space is big help with separating power and signal wires so having the extra real estate is a boon for multiple reasons.
guest1632
  • Guest
Re: Complete 2-Ch Hypex Amp Kits $495
« Reply #17 on: 13 Nov 2005, 01:08 pm »
Quote from: Kevin Haskins
Hypex Amplifier Kit
Hi Kevin,
So what is the difference between the SG and the HG supply. On the UCD400, there are two? power supplies to make up the HG supply. Could you explain a bit more? On the 400 supply, you are using a 500 VA transformer? That would be for the single supply. If left on, what do both amps draw in idle mode? If not much, concerned what the need for standby is for?
Ray
kfr01
« Reply #18 on: 13 Nov 2005, 04:17 pm »
Ray:
From his website:
"The Hypex HG (High Grade) power supply has all the functionality of the standard power supply with full DC protection, on/off mute toggle and built-in bridge rectifier. What differentiates the HG model is the use of premium slit-foil electrolytic capacitors and ultra-soft recovery diodes bypassed by snubber caps. In addition, this premium supply offers a full 40,000uF of capacitance to supply two full UCD-400 or UCD-180 modules."
That answers all but your idle power question.
guest1632
  • Guest
« Reply #19 on: 13 Nov 2005, 10:05 pm »
Quote from: kfr01
Ray:
From his website:
This be true. I wrote him that question about 3 this morning. So I really did not look at the site to well. To think you can get a killer stereo amp in a complete kit form for $500. That's a steal.
Ray
