0 Members and 1 Guest are viewing this topic. Read 6232 times.
As for substituting the LCY for the G2, this is only being done in order to mount the W18's closer together than would be possible with the G2. While the LCY has slightly enhanced dispersion and upper extension as compared to the G2, there will be no audible difference between the two tweeters.
Is that theoretical or actual frequency response? If it's actual, how do you measure it? I can see using a sine wave generator for input, but most microphones aren't calibrated past 20kHz.
the main advantabe will be a lower crossover point, which is very important in an MTM.
Quote from: DMurphythe main advantabe will be a lower crossover point, which is very important in an MTM.Dennis, would you mind educating me a bit? Why is a lower crossover point important for an MTM design?Hi That's because of an MTM's uneven vertical dispersion due to interferrence between the two woofers. On axis, the two woofers will image in the center at the tweeter position, and the crossover is designed to give flat, or whatever contour you want, on axis. As you move to the sides, the only thing that will change is the inherent horizontal dispersion of the drivers, and the response should stay fairly flat if the designer has done enough homework. But Euclid gets into the act as you move above (or below) the tweeter axis. The higher you go, the greater will be the difference in the relative distance of the two woofers, since they are mounted vertically and apart from each other. This will change the relative arrival times from the two woofers, and that will affect phase. The two woofers will start to get out of phase with each other, and frequencies in the midrange and upper midrange will start to cancel. I have a measurement of that here: http://murphyblaster.com/content.php?f=gem_mod.html Go to the bottom of the page. That doesn't change the on-axis response, but it does affect the overall room power response, including all reflected sound. And it affects the sound when you stand up. The way to minimize (but by no means eliminate) the problem is to get the woofers as close together as possible, so the relative distances don't change as much off-axis vertically, and to cross as low as possible to narrow the range where the woofers will interact. Thanks!
Your design will be offered as a Veracity HT2
Personally, I'm hoping for the open, airy. spacious sound with detail and neutrality.Able to listen at low levels and of course crank it up and remain clean and non-fatiguing.You know, rosin, horse hair, gut strings, .50 cal machine guns, everything.
