Thread Size
Roeland
Thread Size
« on: 2 Nov 2005, 11:03 am »
Hey everyone,
Does anyone know the thread size for the HPS-906? I'd like to substitute the original spikes with Soundcare Superspikes.
I already emailed Hyperion in the beginning of September. Albert kindly replied he would pass on the question to the technical service (14/9) and since then I've heard nothing what so ever. Meanwhile, the hole in my floor and my girlfriend aren't very happy :)
Greetz,
Roeland
Roy S
Thread Size
« Reply #1 on: 2 Nov 2005, 03:18 pm »
The thread diameter on the 938 is 8mm, should be the same for the 906.
Rgds.
Roeland
Thread Size
« Reply #2 on: 2 Nov 2005, 04:10 pm »
Thanks A lot Roy :) You're a real floor and relationsaver ;)
So then M8 is the size I need, right? I've never been good at these things  :oops:
Roeland
Occam
Thread Size
« Reply #3 on: 2 Nov 2005, 04:21 pm »
Roeland - I don't doubt that Roy is correct. But it would be simple to go to a local hardware store and buy M6, M8.... nuts, and see which one fits on the  spike's thread you've removed from you speaker to verify the size. Or simply take the spike to the hardware store. It never hurts to check and verify before ordering and spending substantial sums.
Roeland
Thread Size
« Reply #4 on: 10 Nov 2005, 10:45 am »
Thx Roy and Occam,
I checked, approved and ordered :) The Soundcare SUperspikes are on their way...
Roeland
