How to link to gallery?
0 Members and 1 Guest are viewing this topic. Read 1998 times.
gorgeousgeorge
« on: 9 Oct 2005, 10:45 am »
Hello all,
I want to create a link to my gallery when i post, like most of you have, but i don't know how to do it.
any help would be great.
Cheers, George
EchiDna
bubba966
« Reply #2 on: 10 Oct 2005, 06:38 am »
George,
You need to go to your profile and input the link to your gallery in the signature area of your profile. And then you need to check yes to the option of "always attach my signature".
The URL for your gallery is
http://www.audiocircle.com/circles/modules.php?set_albumName=gorgessgeorge,-AKSA-55N&op=modload&name=gallery&file=index&include=view_album.php
An example of the link you need to install would be {url=http://www.audiocircle.com/circles/modules.php?set_albumName=gorgessgeorge,-AKSA-55N&op=modload&name=gallery&file=index&include=view_album.php}My AKSA Gallery{/url}
Just change the { & } to [ & ] in the above to make the link work. To change what the link says in your signature just replace the "My AKSA Gallery" with whatever you'd want it to say.
gorgeousgeorge
« Reply #3 on: 10 Oct 2005, 07:34 am »
Thanks for your help Bubba and Echidna,
I think ive done it right Bubba, we'll soon see after I post.
Cheers, George
AKSA
« Reply #4 on: 10 Oct 2005, 07:39 am »
Thanks Guys,
You know this stuff far better than I......  I have the software skills of a gestating dodo...... :lol:
Hugh
EchiDna
« Reply #5 on: 11 Oct 2005, 04:22 am »
well it works ;-)
*clap clap*
and very neat work on your 55 george....
AKSA
« Reply #6 on: 11 Oct 2005, 05:49 am »
Nice job, George!!
One point;  bend the drivers so that they are all square on against the heatsink, and dress all resistors and caps so they are aligned.
This makes a damn good job flawless......
Hugh
gorgeousgeorge
« Reply #7 on: 12 Oct 2005, 08:06 am »
Thanks guys,
Im happy with it so far, just got to buy my toroidals now so i can test it, only problem is i dont have a preamp yet, my yamaha doesn't have pre outs unfortunately, Im saving my hard earned $ for a the TLP and Aksonics kits.
also Hugh, i had trouble lining up the transformers on the second heatsink, they are only slightly off because i had to drill and tap the holes myself on the extra heatsink i brought, I hope this does not cause any problems?
Cheers, George
AKSA
« Reply #8 on: 12 Oct 2005, 10:30 am »
HI George,
Do you mean drivers?  If so, no problem, it's just cosmetic, absolutely no issue with operation!
Hugh
gorgeousgeorge
« Reply #9 on: 12 Oct 2005, 10:54 am »
sorry, yes  i meant drivers, still only an amateur.
good, i was a little worried, it still bugs me though, im a bit pedantic about things like that, can't stand to walk into peoples houses to find crooked picture frames, maybe i have an obsessive disorder!! :lol:  :o
Cheers, George
