Teac a-L700p inductors need changing
0 Members and 1 Guest are viewing this topic. Read 1733 times.
rotcoddam
« on: 26 Sep 2005, 05:16 am »
I've already modded the heck out of it and just thought this would be a small upgrade, but I just changed out the stock inductors to the ones Tripath specifies (AW600-06-48T-24-V) and, wow, it made a huge difference in the overall presentation and dynamics.  Better mids and highs. The dynamics in this amp are amazing now. Paid $3.65 each through Amidon. Well worth it. They have a minimum order so get some for your friends.
Download the pdf file eb-tk2050 at
http://www.tripath.com/data.htm for more info on these.
Vinnie R.
    • http://www.vinnierossi.com
Re: Teac a-L700p inductors need changing
« Reply #1 on: 27 Sep 2005, 11:02 am »
Quote from: rotcoddam
Hi rotcoddam,
Thanks for posting your findings.
I'm a little hesitant to swap the inductors on the Red Wine modded Teac because it sounds so well balanced, with plenty of dymanics and a sweet top end (mostly the result of removing the stock switching power supply and using SLA battery power).
Still, I am definitely interested in those inductors you tried and will see if I can get some to try out.   8)
Thanks again,
« Reply #2 on: 28 Sep 2005, 09:30 pm »
Please keep us posted on this issue Vinnie.
