<Definitely not a $150 experiment! Try the Parts Express vinyl damping sheets. Way cheaper, and will probably have some effect on 1/2" MDF.>
I'm with Nelgan all the way on that as I don't think the Polk's are that expensive to start. The Parts Express vinyl damping is worthwhile stuff for something like $28.00 a good sized roll.
I have a cheapo Radio Shack LX-8 that I've modding on the cheap here...I liked their Linaeum tweeter and half decent Peerless woofer.
I rewired them internally, set on heavy stands with sand and are running them on active crossovers now...nothing, but nothing was as cost effective or as effective as $28.00 worth of Parts Express Vinyl Damping inside and out. Not even close the other mods were.
It's not that awful looking that you can't use it outside and it won't muck up internal dims as it's very thin. I have it on every wall of cabinet.
The Radio Shack uses 1/2" particleboard..how's that for crap! So, the damping was extra effective as it started out worse then your Polk's walls in MDF.
Enjoy -
