LCR's in Birds Eye Maple
0 Members and 1 Guest are viewing this topic. Read 8996 times.
Brian Bunge
« Reply #20 on: 4 Oct 2005, 09:11 pm »
There is a small hand-held tool called a laminate trimmer.  I bought a PC unit for about $100, IIRC.  For through holes or recesses which are over 1/8" deep I use a 1/8" spiral downcut flush trim bit that has a small brass sleeve on the end that acts as a guide.  If they're right at 1/8" deep then I use a different bit that's 1/4" in diameter and has a single cutting edge and a flat bottom that's just under 1/8" thick.  Smaller than that, and I cut my through hole first, use a rabbeting bit of the right size in my router to cut the recess in the cabinet, and then use that same bit at the appropriate depth to trim the veneer afterwards.  You could even only cut the through hole and then cut out the recess after the cabinet is veneered.
You can see what the spiral downcut bit looks like (it's the top pic):
http://www.routerbits.com/cgi-routerbits/sr.cgi?1128460012_30912+98
Here's the laminate trim bit that I use for the shallow recesses (it's the bottom pic):
http://www.routerbits.com/cgi-routerbits/sr.cgi?1128460012_30912+2
Let me know if you have any other questions.
kfr01
« Reply #21 on: 5 Oct 2005, 02:08 pm »
Brian:
Excellent.  Thank you.  Those are exactly the bits I was unable to find at Lowes.  :-)
Thanks again!
Brian Bunge
« Reply #22 on: 5 Oct 2005, 02:29 pm »
You are quite welcome.  I forgot to mention, you might want to check out www.mlcswoodworking.com to see if they sell similar bits.  They've got very nice quality bits at really cheap prices.  I bought a 1/2" diameter flush trim bit with a 2" cutting length for $13 plus shipping!
