Audio/Video Gear and Systems
Owner's Circles
VMPS Speakers
RSorak
Cabinet bracing
Cabinet bracing
0 Members and 1 Guest are viewing this topic. Read 2151 times.
CornellAlum
Cabinet bracing
13 Sep 2005, 09:12 pm »
I would like to add some bracing to my mls 626r cabinets. I can literally feel the resonance, and as such, would just like to try this tweak if you will. Does anyone have any suggestions as to what to use, where to put them, etc?
Daryan
zybar
Volunteer
Dutch and Dutch 8C's…yes they are that good!
Cabinet bracing
13 Sep 2005, 09:13 pm »
Do a search on bracing as we discussed iy quite extensively in the past.
A few people have successfully added bracing to their 626's and 40's.
George
CornellAlum
Cabinet bracing
Reply #2 on:
13 Sep 2005, 11:01 pm »
I'll give it a try. I was at work and being a bit lazy as I was REALLY busy!
D----
CornellAlum
Cabinet bracing
Reply #3 on:
23 Sep 2005, 01:24 pm »
I am going to giove this a try this weekend. Did you folks who used dowel rods have success? That seems like the easiest solution to me!
D-----
Marbles
Cabinet bracing
Reply #4 on:
23 Sep 2005, 03:48 pm »
Dowels seemed to work very well on my RM40's.
JoshK
Cabinet bracing
Reply #5 on:
23 Sep 2005, 04:32 pm »
I used dowels too, worked fine but theoretically isn't the best solution. Oh well, practically it works.
CornellAlum
Cabinet bracing
Reply #6 on:
23 Sep 2005, 05:29 pm »
Thanks fellas, I am going to give it a whirl and will post if I hear anything different. I assume I need to be pretty exact on placement, any sugestions? I have read through the archives, just FYI.
Owner's Circles
VMPS Speakers
RSorak
Cabinet bracing
