0 Members and 1 Guest are viewing this topic. Read 10465 times.
Nice!Have you tried running Nuforce full way to see how it does the mid/highs?Are you using your SVS subs with 2 channel. If so, at 40Hz lowpass? John brought his subs in at 35 Hz and really complemented his RM30s which roll off around 30 Hz. I am not sure what you mean by peaking at 18Hz. I didn't know that 12" SVS woofers went below 18 Hz, let alone "peaking" at 18 Hz. I am sure they are good subs but they have metal cones which would have different signature than mega woofers Brian uses... Joh ...
Could you elaborate on what the "big cap mod" and "Mega Woofer enhanced sub option" are?Thanks,
I'll take the blame and the thanks.I think the reason I like your system so much is because it is quite similar to mine in many ways.I also have to thank your wonderful wife who has helped you decide on some of the equipment, as well as not only allowed, but "encouraged" you to get it.The reason we didn't think about getting the "bass" tweak of the Ref9s , is because it wasn't known to be available when we ordered, but we can do it on the next order as you say.It makes me happy to see you are enjoying all the changes we have made so far, and its not over yet.
The "big cap mod" that I'm referring to is the replacement of the stock full range input cap on the NuForce amp with a larger capaciter that has better low frequency characteristics. This is supposed to keep the Reference 9 from rolling off the bass at 30-40 Hz. The standard cap is supposed to sound better for mids and highs.
Quote from: mlawson66The "big cap mod" that I'm referring to is the replacement of the stock full range input cap on the NuForce amp with a larger capaciter that has better low frequency characteristics. This is supposed to keep the Reference 9 from rolling off the bass at 30-40 Hz. The standard cap is supposed to sound better for mids and highs.Just to clarify, Jason stated that the stock Ref 9 is configured to go down to 20Hz. The customized version ("Reference 9 woofer mod") supposedly can push ...
Well, as you can see on the from the trace on the bottom, the response starts heading slightly south at 100 Hz and picks up speed at about 40 Hz. http://www.nuforce.com/plots_ref8.htm It isn't a sharp bend and probably wouldn't be noticable on a full range speaker but that probably represents about half of the frequency response of this sub. Don't get me wrong, they put my dental work in jeopardy. Also, the noise figures at the lower frequencies are very nice and the > 4000 dampening makes for very clean and articulate bass. I've just been a bit spoiled with 2 SVS subs tuned to the brown note resonant frequency... http://www.svsubwoofers.com/pb2plusfr.htm
Pay attention to the scale! There is only 0.9db drop between 100hz and 20hz. The FR on NuForce is scarily straight with +/- 0.5db from 100hz to 20Khz. Notice that there is 2.5 db fluctuation on the svs from 20hz to 100hz. So if NuForce is plotted on the same scale as the SVS, you might think that it is a straightline With regards to the 15hz mod, we need to spend some time to test it out and evaluate the sound so we didn't make that an option for customer. The standard Ref 9 already goes do ...
Hey, the gain on the Nuforce Reference 9 is 26 dB, which is exactly what my Jeff Rowland is. This means that I could biamp with the Nuforce (JR on highs/mids and Nuforce on bottom) and not have to worry as much about level matching. I'll have to give that some thought.
The NuForce amps are awesome. The ultimate solution would be to add a VMPS sub to the mix. ...
I can see a larger sub in my future... Jeez John, you have a pair of them in your reference system? Man, I thought I was a bass nut. I don't think the boss will let me get away with a pair of them but after the Outlaw-ectomy/NuForce transplant and the Krell showcase and a better CD, it will be time to break out the big guns bass.
Quote from: mlawson66I can see a larger sub in my future... Jeez John, you have a pair of them in your reference system? Man, I thought I was a bass nut. I don't think the boss will let me get away with a pair of them but after the Outlaw-ectomy/NuForce transplant and the Krell showcase and a better CD, it will be time to break out the big guns bass.Correction: I have TWO pair of LARGERs (that's 4 LARGERS) in my system.
mike, humour some of us - swap the nuforce & ampzilla amps & post your results... doug s.
Quote from: John CaslerQuote from: mlawson66I can see a larger sub in my future... Jeez John, you have a pair of them in your reference system? Man, I thought I was a bass nut. I don't think the boss will let me get away with a pair of them but after the Outlaw-ectomy/NuForce transplant and the Krell showcase and a better CD, it will be time to break out the big guns bass.Correction: I have TWO pair of LARGERs (that's 4 LARGERS) in my system.Man that's got to register on the richter scale. I'm jealous... What are you using to drive this monument to massive bass? ...
