the amp switches at 500Khz and the system runs at 1Mhz.
When there is no load or if the preamp is off (which act as a noise receiver), the amp could overheat.
There are two switching pulses in one cycle and we close the loop at every cycle.
With a 500khz switching frequency, there are 2 zero-crossings per each cycle., we can oversimplified things by saying that the closed-loop response is 1Mhz.
