0 Members and 1 Guest are viewing this topic. Read 3684 times.
Woodsyi or John,Given how close the Largers are to the RM40s, do you have any concerns regarding the magnetism? One would think the Largers are emanating a significant amount towards the RM40's drivers.Nice setup by the way!-KJ
I'll post the results and my impressions, although this might not be for a month, as I have to get the second stand and have a helper (my girlfriend).
I'm going to also be putting my Largers on their sides, as I've purchased some bass traps/stands to put the Largers on. I may also take off the slot, as the sub stands I'm going to get (I have one and am in the process of purcasing the second) are 22 inches wide.A review of ths substand:http://www.stereophile.com/musicintheround/904music/index1.html
As for the sub stands, I think they're a great idea, but I question the expense. Luckily, I'm buying two used stands, which will cost a little more than one new stand. But two new stands would be over $1000. When you consider how many Realtraps you could buy for that, the sub stands are down on my totem pole of room treatments. However, I already have 6 Realtraps (two Mondos, two HF minis and two Mircos) and feel that I could splurge on the stands, especially since I could get them used.
As for the Helmholtz trap, what type are you building? Are you building one in a tube-within-a-tube configuration? ETF allows you to design that type of trap (and also one other, I believe). The problem is getting a high Q (ratio of center frequency to "spread" of frequencies at some point, I think -3dB is chosen). Some people also see these types of traps. I would probably buy two (or several):
