0 Members and 1 Guest are viewing this topic. Read 5117 times.
Another thought. You might consider wiring up the volume control in shunt mode using somethng like a Dale-Vishay RN series resistor. That would keep the stock foot print and remove the pot from the signal path.
I changed the caps in an xcanv2 awhile ago per the Grotto site
QuoteI changed the caps in an xcanv2 awhile ago per the Grotto siteWhat is the url of the Groto site?Thanks.
Hmmm, thinks for the tips, how do you know what version you have?
How would I wire it in Shunt Mode? I am unfamiliar with that. How do you control the volume?
