looking for wattage meters.............
0 Members and 1 Guest are viewing this topic. Read 1981 times.
Sean Jones
« on: 14 Apr 2003, 09:58 am »
Hey, guys.
I am building a rack system with Lloyd's Octal 6 custom kit as the main focus on top, with a Crown DC-300A Series II as the power amp. I am left with two rack spaces left that I will fill with a blank filler panel. I am looking for two 200W round meters with a diameter of between 2" - 2.5"
Any help ?
thanks.
Dr. Lloyd
    • http://www.mapletreeaudio.com
You need VU meters
« Reply #1 on: 24 Apr 2003, 11:16 am »
Hi Sean,
You need audio wattmeters which generally take the form of VU (volume unit) meters which have ballistics suitable for riding the peaks of an audio signal. These read in dB which is logarithmically related to the power in Watts. So you would need an attenuator switch that would yield 0 dB = 200 W, 20 W, 2 W, 0.2 W, etc. You should be able to find a pair of nice old VU meters on ebay from old recording studio equipment, tape recorders, etc. If you tried to use a 200 W linear audio wattmeter, you would hardly ever see the needle move because of the logarithmic response of the ear to power (i.e. your average power will be a few Watts at most).
Lloyd
