0 Members and 1 Guest are viewing this topic. Read 13156 times.
FWIW, Tact gear, when using both the preamp and amp, doesn't lose bits as you adjust volume. That's one of it's great strengths. The preamp passes volume attenuation off to the amp/DAC.The level of playback is controlled by adjusting the voltage of the power supply. To reduce the volume the voltage of the power supply is reduced. This means that the volume control is no longer part of an active circuit.As a Tact user, I'm really excited about the SB2 mods. I would, natuarally be most interested in u ...
