FYI: $43 D-Link wireless/wired router w/ $25 mail in rebate
0 Members and 1 Guest are viewing this topic. Read 1463 times.
JoshK
Just thought I'd pass this info along
http://www.newegg.com/Product/Product.asp?item=N82E16833127143
$43 before $25 mail in rebate for D-LINK wireless router.  I have never gone wrong with D-LINK, and I have had a lot of their gear through the years.
Brad
« Reply #1 on: 15 Aug 2005, 08:53 pm »
If you have long range/multiple floor issues, it might be worth spending the extra $$ to get the MIMO version of the D-Link for $101 less $30 rebate.
JoshK
« Reply #2 on: 15 Aug 2005, 09:27 pm »
yeah, you are likely right that this isn't the SOTA product and it doesn't include a broadband router, which I find indespensible but it would be a cheap way to get your feet wet if you haven't already.
Brad
« Reply #3 on: 15 Aug 2005, 09:46 pm »
For standard G, the D-link you gave is a good choice, especially at that price.
It does include the router function.
NewEgg does a pretty good job on rebates, too.
I got a wireless 802.11b USB nic for $26 with $19 rebate through them.
Just trying to let people know that MIMO really makes a big difference for multiple floors/difficult signal areas.
randytsuch
« Reply #4 on: 16 Aug 2005, 04:11 am »
I used that dlink for a while, but then it went wierd on me, and I would have to power cycle it every couple of days.  That was after a year or so.
Got a good rebate sale on a motorola router at a comp usa sale, I have had to reset it once in about 6 months.
BTW, I live in a two story house, and the dlink was fine for coverage.
Randy
Hogg
« Reply #5 on: 16 Aug 2005, 04:50 pm »
I have a Linksys router that generally works quite well.  I was wondering which of the various routers is least susceptible to interference by other 2.4MHz products like portable phones.   Any advice?  Thanks
        Jim
