Reference ASL AQ 1003 DT - SOLD
0 Members and 1 Guest are viewing this topic. Read 1076 times.
Bill Baker
    • Musica Bella Audio
« on: 9 Aug 2005, 11:16 pm »
Newest versionn with aluminum chassis and wooden remote. Full reference modifications with the following:
* Coupling capacitors replaced with Teflon V-Cap Reference Grade capacitors (x4 pieces)
* Innerstage coupling capacitors replaced with Audience AuriCaps (x6 pieces)
* SoniCap high voltage capacitors used for power supply bypass
* Japanese Riken Ohm Carbon resistors used in grid stop locations (x4 pieces)
* Japanese Riken Ohm Carbon resistors used in screen grid locations (x4 pieces)
* Dale/Vishay 1 watt non-magnetic Metal Film resistors used throughout the signal path
* Mills 12 watt non-inductive resistors used for output tube emitter/cushion resistors
* Fairchild "Ultra Fast - Softy Recovery" rectifying diodes are utilized in the rectifying stage of the power supply.
* Bybee Purifiers installed in the B+ voltage between mains transformer and rectifying bridge.
* All internal wiring replaced with our 22 awg copper wiring. We re-route all signal wiring to provide the shortest path possible. (10+ feet)
* Star Sound Audio Points installed in 3 point arrangement.
* SED EL34 output tubes / EH 12AU7 signal tubes.
* Biased then bench tested for 2 hours prior to shipping
* Labor 6 hours
 Like new condition with less than 100 hours.
 Regular selling price $2,500
 Asking $1,200
Don't expect a lushy, EL34 sound from this amp. The ASL 1003 has a very precise, dynamic, authoritive presentation. Very refined.
Bill Baker
« Reply #1 on: 24 Aug 2005, 08:10 pm »
SOLD
