Clearance cabinets
0 Members and 1 Guest are viewing this topic. Read 3575 times.
RAW
Clearance cabinets
« on: 7 Aug 2005, 09:21 pm »
Black Walnut cabinet
Black Walnut cabinet Specifications
:: 3/4" MDF cabinet
:: Walnut veneer dyed black
:: bracing
:: Grill included
:: Satin finish
:: Includes a single Extremis 6.8 driver
Cabinet size
20" H X 9" D X 14.25" D  Outside size of cabinet 3/4" MDF
Driver hole size cut outs
Tweeter cut out
105mm wide
190mm tall
Woofer cut out
181mm
Port hole cut out
82mm
Holes drilled for 2 sets of termainal post on the back of the cabinets
All holes are pre cut and the hole cut for the Extremis 6.8 is larger than the OD of the frame.
We have a limited amount of these cabinets and we are offering them for a price including the Extremis 6.8 along with FREE shipping.
No changes are offered to the cut out out size.If you would like to do your own changes to the holes or add a new front to the cabinet for other drivers this is a option for you to do so and have a very high quality grade cabinet for a low price
tubesguy
Clearance cabinets
« Reply #1 on: 13 Oct 2005, 03:51 pm »
Hi Al -
Could you tell us what the tweeter cutout is designed for?  This looks like it could be a very nice way to get going on a great speaker. Thanks - pat
RAW
Clearance cabinets
« Reply #2 on: 13 Oct 2005, 04:27 pm »
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=276-420
List Price:  $499.99 EA
Price:  $424.99  EA (1-3)
Quantity Price:  $399.99  EA (4+)
Yes would be a nice MT. :!:
tubesguy
Clearance cabinets
« Reply #3 on: 13 Oct 2005, 07:43 pm »
Ouch!  So much for the bargain idea. :lol:  Thanks for the info, though - Pat
RAW
Clearance cabinets
« Reply #4 on: 13 Oct 2005, 07:54 pm »
Yes .
I under stand.
But for someone who wants to make a plate to fit the cut out and drop in another tweeter.
They are a sweet find.
Marbles
Clearance cabinets
« Reply #5 on: 24 Nov 2005, 07:30 pm »
Do you have a XO for the 6.8/G1?  Do you have schematics for them?
Are these cabs still available?
Thanks.
JoshK
Clearance cabinets
« Reply #6 on: 24 Nov 2005, 08:20 pm »
Maybe the large Fountek would fit?  It isn't so expensive.
RAW
Clearance cabinets
« Reply #7 on: 24 Nov 2005, 10:13 pm »
Yes we still have the cabinets a few more left.
I think maybe 10 left and that is it.
As for a design using the G1 we never did a design for them but could if it is wanted.
The fountek I could not do a design as we do not have the ribbon.
If you wanted to get them and send one for us to design with and then send it back with the cabinets and crossovers we could.
Marbles
Clearance cabinets
« Reply #8 on: 24 Nov 2005, 10:46 pm »
Did you guys see this Agon advert for G1's?
http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1138037806
$550 for the pair.
With the cabinets and 6.8 that Al has, this should be a KILLER speaker for not that much $$$$.
