0 Members and 1 Guest are viewing this topic. Read 12324 times.
Jim,Any idea of pricing on the HT3a's?
In your tests, what have you been using for the 6 channels of amplification?
Glad to hear the active option is progressing, Jim!To be clear, your 3 crossover/correction curves have been driver corrections only? In otherwords, they are based on anechoic chamber measurements and there is no room response factored in at all?Thanks!
I know many of you are probably wondering how the HT3a's sound. Well, they are already sounding quite good. As to how they compare with the HT3 passive crossover version, I have not yet had time to do an A/B comparison. And the HT3's with that Dennis Murphy crossover will certainly be hard to beat. ...
At this point, since you are used to the sound of your speakers, without A/Bing them, have you approached, been even with, or surpassed the passive XO's?Thanks for your thoughts...
One benefit would be speaker correction of all three drivers. The TACT only does room correction. Correction of phase relationships between two drivers could be corrected. In other words, both the low and mid frequency drivers will be playing overlapping frequencies at around the crossover point between the two drivers. With DEQX, one could adjust the phase of the drivers at those frequencies to be the same; with the TACT, this is not possible. The TACT can adjust the phase at any one frequency, but if there's a phase difference between two drivers, both of which are playing the same frequency, then the DEQX should correct for this better than the TACT.
The drawback is the quality of the internal DACs which are not state of the art. ...
Speakers of proper design shouldn't need driver correction, but with some drivers it can obviate the need for a notch filter. ...
I'm sorry if this is a stupid question, but can't the active x-over be set up to be exactly the same as the passive x-over? I mean, at the same frequencies and with the same slopes? Then the sound would be at least as good as the standard HT3 but with tri-amping/room correction/phase correction as well.
Also, if you believe DM's passive x-overs can't be beat, what advantage does the DEQX offer over the Tact used on the standard model with a single high quality amp (such as George's system)?
And finally, I can't wait for my new speakers!
Just curious, not for myself really, but more of a general question; what about those who already own a DEQX, are they precluded from the HT3a?
