Other Stuff
Archived Circles
General Archive
Best tube preamp up to $1500 w/remote volume
0 Members and 1 Guest are viewing this topic. Read 6304 times.
clubmyke
Reply #20 on:
25 Aug 2005, 12:25 pm »
you can get a bat 3vki for $900 - $1200 with remote or a vk-30 (better unit imho) for $1400 - $1800 depending on condition, remote, and phono stage...
rmihai0
Reply #21 on:
25 Aug 2005, 03:42 pm »
If I would have this money to spend for a preaamp they I will get a used Modwright SWL 9.0 SE or new Eastern Electric MiniMax.
You should also consider a used Supratek Chardonnay or Sonic Euphoria PLC if you can find any.
nrenter
I can't believe...
Reply #22 on:
29 Aug 2005, 03:04 pm »
...no one has mentioned the AES AE-3 DJH. This is a killer pre-amp.
http://www.audioelectronicsupply.com/cgi-bin/audioelectronicsupply.com/view_services.cgi?request=detail&dept_id=2&aisle_id=21&prod_num=AE-3_DJH
If you order it new from Upscale Audio, you'll get access to Kevin's choice stock of tubes (you'll pay dearly for the tubes, but they can be worth it).
http://www.upscaleaudio.com
Other Stuff
Archived Circles
General Archive
