0 Members and 1 Guest are viewing this topic. Read 4550 times.
I suspect that there will be several threads regarding the upgrade options that Jim offers, but I'd like to start one that documents how people would rank these options relative to the associated acoustic improvement.I know there have been very few direct comparisons between speakers with and without a particular upgrade, much less in the same system with the same upstream components, but some have at least had the chance to hear multiple pairs of HT ...
Hi Rob,I would suspect the cap upgrade would fall under #1 as well, any thoughts on that??? Thanks Gordy
Under #2, the cap upgrade probably gives the most performance gain.One thing about the cap upgrade, the caps take up so much room, there is no room for an extra brace behind the woofer.So if you go for the (internal) cap upgrade, you should also get the black hole.If you get external XO's, this of course does not apply.It should be noted the brace I'm talking about was not one originally designed in the HT3, but was going to be added at my request after a knuckle wrap test at AKfest. The ...
Is the extra bracing that you're referring to now included in the stock HT3? If I get the cap upgrade, will I get any less bracing than if I didn't get the cap upgrade?
