The site seems to be a bit buggy and isn't allowing pic posting.<----------Check my gallery.
That's a pretty awesome looking setup all in black like that. Do you get much soundstage with the sidewalls so close?
I really like the panels on the back wall. Did order them screen printed or is that DIY?
Thanks. They are from ATS Acoustics and cost less than half the usual suppliers.
Did you get the print from istockphoto or something similar? What category does that kind of design fall under? I'm looking to do something similar.
It was from Shutterstock image number 113463763.
Agreed. The panels on the back wall look great. But those LMS Ultras capture my attention even more so. Is it advantageous for imaging to place the subs like you have them (for music listening)?
