0 Members and 1 Guest are viewing this topic. Read 406194 times.
It's been too long to remember, and I'm too busy at the moment to get them out of storage and set them up. I know the HT3s have a lower base response. And, while the 1290s were very accurate and netural, the quality of the drivers were much less than those used in the HT3s. I loved the 1290s, mind you, but HT3s are in a completely different class. Song Towers might be a better comparision, but I've never heard any Song Towers.Contact Jim and see if there are any owners in your area. Someone will probably let you audition Salks.Chris
Thanks. I contacted Jim and hopefully he can refer me to an owner nearby.Looking again at the prices, realistically I think the HT3 is out of my range, although it would still be nice to hear them to see what qualities you get in such a speaker. Looks like the HT2's are at the top of my range. I wonder how much they are like the HT3s and what are the key differences? If the SongTowers are along the lines of my 1290's, perhaps the HT2s would be a good upgrade?Thanks again. I greatly appreciate all the help and replies.PS - I just noticed that the V3 is also in the price range I'm considering. How does this speaker compare to the HT line?[/quoteSent you a PM ----- Greenhouseman
I've had HT3's, V3's, Archos, Songtowers, and HT2TL's. If your budget only allows $4k, then get the HT2TL's in basic form w/o worrying about upgrades in them. If trying to do an HT set-up them go ST's and perhaps add ribbons if you can swing the cost if you're doing multiple speakers and have the same budget limit.
[snip]I really didn't plan on replacing all my speakers, just the L&R speakers. Hopefully my existing center and surrounds would still work well with the new speakers for HT use.
Personally, I think it's important to match the front 3 speakers for a number of reasons. The rears are less important and can be of a different design/brand/etc. (unless you listen to a significant amount of 5 channel music).Chris
Agreed. Maybe Saturn could best spend his money by getting Songtowers all across the front and adding the surrounds later. That's what I am going to do. If ribbon tweeters are preferred for the 2 channel listening then that could be an option, but for HT I enjoy the dome very much and the ribbon would be overkill (in the dedicated HT).If HT2TL's then the center becomes more expensive and may prevent a complete trio ensemble in short order.
Considering I want something that will be a significant upgrade to my current L&R speakers (ADS L1290/2s), I'm not sure if the SongTowers would suffice. I really need to find a way to audition these speakers!
Hampton, VA is about 2.5-3 hours away from Bethesda, Maryland, the home of Dennis Murphy, in whose basement you will find the only Salk showroom on the east coast, as well as the fabled Salk Sound Research & Development Laboratories.If your ADS speakers can be moved without a forklift, bring one or both, and compare them side-by-side with some Salks. It's well worth the trip.If Dennis is busy, I'm another 20 miles away in Gaithersburg, MD. I have a pair of SongTowers.
Thanks for the great information and the offer.How do I contact Dennis Murphy?
Hello, I am interested in auditioning Salk Songtower QWTs. Located in the Richmond, Virginia area.Thanks,Rob
