WHich interconnect to buy between Catcables, Signalcable...
0 Members and 1 Guest are viewing this topic. Read 4307 times.
guest1632
  • Guest
Re: WHich interconnect to buy between Catcables, Signalcabl
« Reply #20 on: 6 Aug 2005, 06:09 am »
Quote from: michaelv
Hi,
  It's now the time i need to upgrade interconnect in my system. I need 3 pairs as in order followed:
   CD --> Tube buffer
    Tube buffer ---> Pre-Amp
     Pre-Amp ---> Amp
I see there are many reasonable interconnect in the market , but i narrow down to SignalCable, ElementCable and Catcables.
Do you have any experience between them? which one do you suggest? They are pretty much the same in type and price...so it's hard for me to determine.
Also, people are rave about Sil ...
Hi Mitchell, Well, you might want to try a pair of Guerilla cables. He makes both copper and silver. $100 for silver and $75 for copper, if memory serves me right. Go to www.guerillaaudio.com
Ray
michaelv
« Reply #21 on: 6 Aug 2005, 02:28 pm »
Thank you all for your time and opinions.  I have decided to try out Elemencable Twisted II IC with Cardas RCA, instead of bullet plug. I am not a believer in plastic bullet in the long term...:) I'll  find out how Elementcable goes.    Will let you know the result soon.
