Mag cone experiment
0 Members and 1 Guest are viewing this topic. Read 10908 times.
JoshK
Mag cone experiment
« Reply #20 on: 4 Aug 2005, 08:17 pm »
Quote from: Rick Craig
The larger ribbons (Aurum Cantus G1 / Fountek Pro5) will cross pretty low provided you don't mind the narrow vertical sweet spot.
ah...such is life, all about choosing our compromises.
ekovalsky
Mag cone experiment
« Reply #21 on: 6 Aug 2005, 04:56 pm »
If the price of admission doesn't disqualify it, the Raven R3.2MMX would be a good choice.  It is designed to cross over as low as 800hz with a 24dB/octave Linkwitz-Riley.  Impedance is 8 ohm and sensitivity is 98.5 dB.  It weighs 35 lbs -- a lot for a tweeter but half that of its predecessor Raven R3.1 .  MSRP is $1750 ea.
JoshK
Mag cone experiment
« Reply #22 on: 6 Aug 2005, 06:12 pm »
But it has the same vertical dispersion limitations as that of the G1, et al.
ekovalsky
Mag cone experiment
« Reply #23 on: 6 Aug 2005, 06:26 pm »
Quote from: JoshK
True, you'd have to accept a narrow vertical listening window.  Of course one could use multiple units in a line array :idea:
jhenderson010759
    • http://www.innovative-dsp.com
Cones have landed...
« Reply #24 on: 6 Aug 2005, 06:37 pm »
New Seas have arrived.  The black, mag-cones are a beautiful match for the black baffle on my enclosures - much nicer than the white-cone version IMO.  Phase plug is still a beautiful copper bullet.
I mounted them in that cabinets this morning, and will run some sine-sweeps using the DEQX during the next period of relative quiet here at Chaos Manor.
The Ravens sure look like a magnificent driver, but they'd certainly require an all-new enclosure.  I'm leaning towards building a pair of Orions, following this work.  If that happens, I'd use these Rhythms to replace my rear, ambience-recovery channels and bring the Orions up front.
OTOH, I now have four SS8545 mid-woofers and four great dome tweeters that need a home.  And, the speakers in my garage rig are junk...
Jim
John Ashman
    • http://forum.adnm.com
Mag cone experiment
« Reply #25 on: 6 Aug 2005, 08:14 pm »
Jim, any physical difference with the new SEAS driver?  I missed something, did they upgrade them?
Bingenito
Mag cone experiment
« Reply #26 on: 6 Aug 2005, 08:15 pm »
Must be the W18e001 not the EX. Unless Seas is now making the W18Ex001 available in black. If they are let me know because I will order 2 on Monday :D
jhenderson010759
Not the EX
« Reply #27 on: 6 Aug 2005, 09:06 pm »
Minw use the standard magnet assembly.  I saw no virtue in the EX in terms of distortion performance or frequency response, though the EX is more efficient.  But, that's irrelevant in my application, since the DEQX compensates for driver efficiencies and the MTM configuration I'm using provides 2x greater efficiency in the midrange already.
jhenderson010759
Cosmetic difference...
« Reply #28 on: 6 Aug 2005, 09:20 pm »
Quote from: John Ashman
The cones are black, instead of white.  That's the only difference.
jhenderson010759
Pic of installation
« Reply #29 on: 7 Aug 2005, 01:07 am »
Picture of new drivers...
