Transformer to use an intergrated amp as a headphone amp?
0 Members and 1 Guest are viewing this topic. Read 1795 times.
Loftprojection
Anybody knows if there exists another transformer then the AntiqueSoundLab UHC to be able to use a regular integrated amp to power headphones when the integrated amp does not have a headphone plug?
Here is the ASL UHC link so you guys know what I mean:
http://www.divertech.com/asluhcsignature.html
There must be someone else making such a product for a cheaper price and that does not necessarily have a switch with in and out speaker binding posts.  I want something very simple.  This one is really neat but more than what I'd like to pay.
Thanks for your help.
jmc207
« Reply #1 on: 2 Aug 2005, 07:35 pm »
I used to have a inexpensive little adaptor box made by QED that hooked to the speaker cables. However, this was probably 10 years ago. There is this John Risch post on Audioasylum about a resistor network you can build:
 DIY High Quality Headphone Output From Amp Output
http://db.audioasylum.com/cgi/m.mpl?forum=general&n=253385&highlight=headphone+Jon+Risch&r=&session=
Loftprojection
« Reply #2 on: 4 Aug 2005, 06:41 pm »
Thanks, that should be a very cheap solution to my problem.
