RC, just remember the Isonodes are rated for a small range of load (weight). If you go over or under their rating by adding more Isonodes, it may not be as effective. I personally would change my listening height at the chair than try to change with Isonodes which may not be stable the way you decribe using them.
RC...Dude you're killing me! How about just listening to the isonodes as I have prescribed, before your quest for a Rube Goldberg contraption? You're missing out on the music!!
Roy,The isonodes will leave a thin residue on the piano finish, but it can be removed with a damp cloth. If left on long term, I don't know if permenant damage will occur. I do recommend using separate small sheets of Seran wrap on top and bottom of the isonodes to prevent residue.As for the stability, the upper cabinet will mildy wobble if you push the cabinet, but if you use the smaller isonodes like Rwolters, it will probably be minimal. The improvement is very significant and readily apparent, better than cable upgrade IMO.It's dirt cheap too .
Someone I know is bringing some Isonodes from the States for me by the end of September... I'm very curious aftrer reading all this...Another tweak I'll try out for my 906 is filling the lower cabinet (the hollow stand) with a garbagebag, filled with +- 100 pounds of sand for improved dampening and stability.Greetings Roeland
I am currently using the Bright Star Isonode Sorbathane feet under the mid/tweeter module. They certainly are improvements over the stock feet.I have read great feedback about the Herbie Big Fat dot (http://herbiesaudiolab.net/spkrfeet.htm#von), which have significant improvements on Von Schweikert. One comments suggested that:"Decoupling with compliant materials like Sorbothane is usually worse. Your intuition about compliant interface, with speakers, is correct. With compliant materials, the idea isn't to let vibrations dissipate, but is to absorb vibrations (transfer the energy to heat). Rubber and Sorbothane, and most squishy materials will absorb some vibrations but yet by their compliant nature will also allow the cabinet to vibrate unconstrained to some degree. Then, rubbery materials will introduce resonances of their own into the cabinet that affect the speakers' drivers. Any benefit you get is usually at the cost of some detrimental trade-off.Have anyone of you tried the Herbie Big Fat dot and compare that to the Isonode?
Hi I ow a pair of Hyperion 938s and want to change the crossovers and generally upgrade.I live in Abu Dhabi home is Ireland .Spoke by E mail to John in Russ Andrews who was most helpful .Can this upgrade be done on a DIY basis.I believe the rear panels of the lower unit have to be removed to gain access to the inside.Has anybody done this as I am concerned over making a total mess of the piano black finish.ThanksAlanJL
I spoke to John in Russ Andrews who suggested because the 938 is a complex speaker. The task of changing the crossovers was not exactly simple and he did not have all the info at hand on the work they done for a previous customer.I think I will err on the side of caution and wait till I return home and send the units to RA and let the professionals do it.Thanks for the link ::
Hey, thanks for the great forum. I just picked up a pair of 938's and was shocked at how glaring the midrange was. The previous speakers in the hot seat were my Spendor SP1's which have a pretty amazing midrange, so the competition was pretty tough.I was just about to sell them after about 30 minutes of listening, then I discovered the post about the Isonodes. I just tucked them under the midrange cabinets and the results were pretty dramatic! I'm going to fool around with room placement and treatments now to further improve the sound. Thanks for the tip!!
