Line input transformer
0 Members and 1 Guest are viewing this topic. Read 1679 times.
SamL
« on: 26 Jul 2005, 05:49 am »
There's a group buy for Jensen line input transformer over diyaudio.
http://www.diyaudio.com/forums/showthread.php?s=175c5a5e0b788bda8a67554cc0bdf6b6&threadid=61280
It is a worthwhile add-on to AKSA amp to filter out input noise?
Gordy
« Reply #1 on: 26 Jul 2005, 06:11 am »
Those are very good prices!  I think I paid $110 american for mine.  They are very transparent, but I've only used it for certain configurations when a ground hum will pop up, almost always when a Carver zr1000 is involved somehow.  Works a treat and vastly preferable to lifting a ground imho... sorry I couldn't actually answer your question...
Raj
« Reply #2 on: 26 Jul 2005, 04:06 pm »
Hi,
Only Hugh can truly answer this question,
but If the AKSA has a dc blocking cap at input, you could do away with it and use these, they are a lot more expensive than a cap though. In my experience, and a lot may not believe this, but well wound transformers often outperform cap resistor/combinations when used for coupling. I have used them in ouput stage as well as attenuation and both times they came out sounding more natural and more dynamic too. It is something you have to experience to believe.
Raja
AKSA
« Reply #3 on: 26 Jul 2005, 10:49 pm »
Hi Sam,
A transformer of itself will do nothing for noise.  These things are useful only where there are very long interconnects from the source in a noisy environment;  the classic situation is a rock venue or studio, with lots of lights and high power spikes floating around.
If your interconnects are more than 3 metres, if you have a noisy electrical environment (dimmers, strong lights, a few 500W amps, perhaps a 5Kw electric motor or two), then you have a good case.  But you will need a balanced source, and balanced lines.  Then you can use the transformer with balanced input and single ended output;  this will obviate the input cap on the front of the AKSA but it will add transformer distortions which are not the same as capacitor distortions - usually greater.  The Jensen is an excellent trafo, a standard in the recording and pro-audio industries.  I have one courtesy of a very kind Doctor in California, but they are only noise reducing components if used in a noisy environment with a balanced source and properly loaded coaxial, balanced lines.  Domestic high fidelity systems are not generally located in noisy environments and in this scenario there is no perceived benefit.
Hope this is helpful,
Hugh
