Phono stage +power supplies
Deckman
« on: 18 Jul 2005, 08:47 pm »
Hi, having just finished the turntable power supply, which I'm very pleased with! I decided to have a go at the Phono stage using two of the cascode power supplies (one for each channel) in a separate enclosure.
Now comes the tricky part, I've got a bag of bits in front of me together with the circuit diagram and board layout. With time and a little care I could probably populate the boards ok, but electronics is not my discipline and the circuit diagram means little to me, other than a string diagram joining the components. What would be really useful is some pictures of a completed unit, especially showing the connections to and from PCB, and any hints or tips on things to do, or not to do!
