Do you cover fiberglass with anything beside burlap?
0 Members and 1 Guest are viewing this topic. Read 5597 times.
michaelv
« Reply #20 on: 21 Jul 2005, 03:44 pm »
Ethan,
  I thought the bass trap will take care of it .  I now have two 4" thick bass traps in the two corners in front of speaker  and foam bass trap (I will build 2 more 4" bass trap to replace it) in the corner behind speaker.
  Since the room is small, so that's much can move around. Can probaly move a chair up a bit , but only 1ft more won't make difference , i think.
  So,  are you suggesting that i put 4" panels on the rear wall (behind my seat) too or 2" panel will do?  Do i need to cover the whole rear wall?
thanks.
bpape
    • Sensible Sound Solutions
« Reply #21 on: 21 Jul 2005, 07:25 pm »
For the reflection points, 1" spaced off 1" will be just fine.  I think that would be a better option for you - then you could use the 2" you have now for the reflection point and double it up in the corners to give you 4" there - much more effective.
Ethan Winer
  • Audio expert
« Reply #22 on: 22 Jul 2005, 11:52 am »
Michael,
The thicker the panels, the lower in frequency they absorb to. And by extension, the lower in frequency they solve problems to. It's as simple as that.
--Ethan
