0 Members and 1 Guest are viewing this topic. Read 9792 times.
"you gatta love a well exectuted blumlein recording"Damn right! It's the only recording I have out of 400 others that images fairly realistically. d.b.
csero wrote:[The Blumleins setup has lots of problems. Can be nice but faaaaaaaar from realistic. Blumlein himself knew about the problems.]sorry - don't know how to do the quote windowI would be interested in knowing more about the problems that Blumlein was aware of.Russell
its things like "exessive ambient pickup" that add to the depth and width of the sound stage. ...
those rear lobes of the figure of 8 polar pattern are out of phase w/the forward facing ones.with a blumlein config, you get those two rear lobes...which overlap w/the opposite forward lobes of each microphone. its that out of phase info which makes it sound so sweet. You just dont get enough of that information with other directional microphones. ...
http://www.mtsu.edu/~dsmitche/rim456/Materials/456microphone_techniques.html this has a nice diagram of what is happening with crossed figure of 8 mics. ...
I received my copy today, thank you Russell. Excellent recording !! If you've not heard it, I'd contact Russell for a copy...well worth owning. Chris
lonewolf said:QuoteI received my copy today, thank you Russell. Excellent recording !! If you've not heard it, I'd contact Russell for a copy...well worth owning. ChrisChris has never steered me wrong so I bought all three versions. They arrived Tuesday. Can't wait for a quiet time to give them a listen.Thanks Russell!
3 versions? If I remember correctly, the original version (which I bought) had a small amount of leveling applied, and then a second, completely unlimited version was released. I didn't see any mention of a third version in the thread... how is it different?
Hi Jeff, yes, I do have CDs still for sale. I have 3 versions: 1) mastered with compression, 2) mastered without compression and 3) unmastered. If you are interested in it for simple musical enjoyment, I would recommend the mastered with compression version if you are buying only one. The others are mainly of technical interest to some, or as a demonstration of why compression is a good idea on dynamic orchestral music! Mastering in this case involves altering the soundfield a little to fill in the center rear of the orchestra, adding a small amount of EQ to compensate for microphone characteristics and distance, and subtle compression to raise the levels of the pianissimo violin passages to be easily audible without blowing out your speakers on the loud bits. 2) is the same as 1) but without the compression. The unmastered version (3) is exactly as it came off the master tape. None of these have any reverb added.
