Cornet2 cap question.
0 Members and 1 Guest are viewing this topic. Read 1323 times.
rotcoddam
« on: 3 Jul 2005, 03:28 am »
OK, so I have some Wima 1uf's in the c200 and c206 position and I was wondering if it's worth changing these to something better, like auricaps. Will a better cap change the sonics much or are the wimas ok?
hagtech
    • http://www.hagtech.com
« Reply #1 on: 3 Jul 2005, 05:30 am »
It depends on what type of WIMAs you have.  The sound will change, as each cap leaves it's own signature.
jh :)
Eric H
« Reply #2 on: 4 Jul 2005, 10:59 pm »
That's a good question...  I'm not sure how much those bypass caps influence the sound, and I haven't experimented with mine, but I did upgrade to Jupiters in the signal path...  (they aren't recommended for use as bypass caps).  I might guess that a nice upgrade would be to replace the electrolytics with Solens or similar, and I don't think you would bypass them...(?)  If you try something different report back - I'm interested...
