Question for James: BP-16C Volume Control
0 Members and 1 Guest are viewing this topic. Read 1958 times.
jethro
« on: 29 Jun 2005, 11:42 pm »
There's a press release on Bryston's site announcing a new pre-amp for those who haven't seen the announcement:
http://www.bryston.ca/pdfs/MemoBP16PREAMP_SST.pdf
James,
Firstly, I hope you don't mind me posting the URL.
The announcement says that the pre-amp will have a new volume control. Could you exapnd on this a bit ?
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 1 Jul 2005, 10:04 pm »
Hi Jethro,
This is a Dan question - the engineer behind the B100.
james
« Reply #2 on: 20 Jul 2005, 03:07 pm »
Hi jethro,
Sorry it took so long on this.
This is from a recent German review on the B100.
"There are a number of clever audiophile design features including a very modern digitally controlled volume control using a resistance network on a chip.  Mind you, this technology, in reference to the signal path, is located in the analog section and offers many advantages, for instance perfect channel balance, a simple integrated balance adjustment without additional parts, practically zero adjustment noises, first class behavior in reference to noise and distortion, as well as adjustment via software.
james
jethro
« Reply #3 on: 22 Jul 2005, 12:45 am »
Thanks for the info  James.
Since the volume control is digitally controlled, have you though of adding the feature to have the volume return to a preset value at power-on ?
« Reply #4 on: 22 Jul 2005, 12:07 pm »
Hi jethro,
I assume we could do that in software but I will check with Dan.
james
« Reply #5 on: 22 Jul 2005, 02:41 pm »
HI jethro,
Yes it would be possible to have a preset volume. We just have not written the code for it yet.
james
