tube amps
0 Members and 1 Guest are viewing this topic. Read 4170 times.
DVV
tube amps
« Reply #20 on: 8 Jul 2005, 07:19 am »
Quote from: Carlman
If you have a small-ish or even medium sized room (10x10 up to 14x17) tube gear or class A SS will heat up the room at least 5*F to as much as 15* or more... I've been over to a fellow AC member's house with a Cary tube amp... wearing shorts and a t-shirt is a prerequisite because it's so hot in that little room.  There are others here on AC that have a 'winter amp' and a 'summer amp' for this reason.
The EL34's w/ lower wattage aren't bad... and in a medium to large room won't heat the room much... but  ...
Good point, Carlman, you beat me to it. :mrgreen:
Solid state amps, even those made to run with higher bias currents than the norm (this typically but not exclusively being 20...45 mA per trannie in Japanese amps and 35...65 mA per trannie in European amps), will also heat up the place.
My own designs use no less than 150 mA per output device; there being four pairs, the overall quiescent current is 600 mA, which, at +/-50V rails, means the output devices pairs are dissipating around 10 watts each, or around 40 watts overall. Although I use rather massive heat sinks, after about 30 minutes, they reach a healthy temperature, warm to touch. If I should increase the bias current, the "warm to touch" becomes a little hot.
Not quite what the glass tubes do, but not too far removed either.
DVV
  • Speakers....What Speakers ?
tube amps
« Reply #21 on: 8 Jul 2005, 08:42 am »
Carlman wrote:
    If you have a small-ish or even medium sized room (10x10 up to 14x17) tube gear or class A SS will heat up the room at least 5*F to as much as 15* or more...There are others here on AC that have a 'winter amp' and a 'summer amp' for this reason.
    [/list:u]
      Yep...the Krell, runs class A, and it was a killer in the summer...but toasty in the winter. The AKSA cured the summer heat problem....runs cool....thanks to Carl !!! :thumb: [/list:u]
      However, I've found Butler amps not to increase the room temp AT ALL. I think this is because the design runs the tube section at very low voltage... which does 2 things; lengthens the life of the tube and lowers the heat...
      [/list:u]
        The Butler is another low temp amp...a hybrid. Comparing the AKSA and Butler...temp wise...the AKSA runs slightly cooler. But both are much better than the Krell for summer use where heat is a problem. 8) [/list:u]
      jt1stcav
      • Li'l Sammy...she loves directly heated triodes!
        • http://www.freewebs.com/jt1stcav/
      tube amps
      « Reply #22 on: 10 Jul 2005, 06:21 pm »
      The heat from my 300B SET amp and 6SN7 SRPP linestage pre is noticable for sure, but with central AC and a ceiling fan, it's not an issue for me.
