0 Members and 1 Guest are viewing this topic. Read 3103 times.
John,I tried the RM/X both ways. Like you said results will be very room dependent. As you did, I only measured (via TacT) at the listening position.Response in the second octave (32-64hz) was better with the side woofers facing inwards. But there was unbelievable suckout around the bass-planar crossover frequency that was impossible to fix even with a TacT.With the woofers facing outwards output in the second octave wasn't as strong but the huge suckout around 200-300hz pretty much went away ...
Interesting that the Low Bass woofer firing angle had a "filtering" effect on the 200-300Hz range. You would think that at frequencies that low (below 200Hz), that shouldn't happen to that degree.Obviously you used the same convergence angles and positioning. Sounds like your bass towers "load" the room much better and that even though they are not in the same (presumably) "acoustic plane", the TACT can adjust Phase to make it work better.I just spent the last 45 minutes "re-positioning" (as in ...
I would expect the GR woofer towers and the Selah Citrine subs to perform basically as well as the Alon towers at a much more accessible price.
Am I the only one on here that is sick and tired of hearing about Eric's speakers. Jeesh, this is the VMPS forum, and while I congratulate him on his purchase, I will probably never own his speakers, much less hear them, so please, if you could, post about your speakers in another forum, it's getting ridiculous.
Quote from: CornellAlumAm I the only one on here that is sick and tired of hearing about Eric's speakers. Jeesh, this is the VMPS forum, and while I congratulate him on his purchase, I will probably never own his speakers, much less hear them, so please, if you could, post about your speakers in another forum, it's getting ridiculous.Since Eric has owned multiple VMPS speakers I think he is quite qualified to discuss their virtues and flaws in this forum.Just because he doesn't always have gu ...
Hey John, i understand what you mean about competitors. But seriously, the Alon Grand is a system costing over 100K !!! Thats more than 10 times as much as the RM/X. I dont think Alon and VMPS are competitors. If he bought some B&W800D, Dynaudio, GR Research etc.. i would understand it.-FloPS: I love my VMPS, and i currently have a RM30 and 626 here. I sold a third RM30 to my customer and he is also very happy with the sound.
Please re-read what I said. My request was limited to "other" AudioCircle manufacturers.The proximity of our community (AC) makes promoting, or criticizing products of another circle a bad idea.I think we have rather spirited discussion about the "perceived" flaws and virtues of VMPS without too much problem.
Well maybe i missunderstood it then. I thought John was reffering to the Alons. Did i understand it wrong?
