Optic Cable changes bass output ?
durholt
« on: 16 Jun 2005, 07:41 pm »
H/K AVR 525
5 Emeralds
1 Force
Toshiba DVD player
I recently upgraded my cable to digital and discovered HD and Digital sound improvements, but noticed an increase in Bass (response?). I decided to change my DVD connection from RCA to a Digital Fiber cable. I did a questionable thing and purchased a $20 cable from Target to see if there would be a difference. The sound is much improved, but the bass is much more amplified. Is that a quality of the digital cable? Should I simply adjust my Force volume down. I do not want to risk over/under powering the sub and somehow hurting it.
Any input is great.  Thank you,
Mike Dzurko
« Reply #1 on: 16 Jun 2005, 09:03 pm »
I'd start by just adjusting the bass level down to be even with where it was.  No need to worry, you can't really hurt the Force.
durholt
« Reply #2 on: 16 Jun 2005, 10:14 pm »
I will do that... thank you very much... Is there a reason the cable change would cause that. Is it just better quality or are the $20 Monster cables junk?
