Need mid-panel upgrade help!
0 Members and 1 Guest are viewing this topic. Read 1730 times.
Ernest
« on: 6 Apr 2003, 09:01 pm »
OK, I'm an idiot.  When I unsoldered the old panels I did not mark which wire went to which part of the panel.  Now that I have the new panels I have no idea which wire goes where.  Each speaker has a red wire and a red wire with a green stripe.  Each panel has two connectors, one silver and one silver with a red tip.  Can anyone tell me which wire goes to which connector?
Ernest
JoshK
« Reply #1 on: 6 Apr 2003, 10:03 pm »
My guess is the red wire goes to the red tip, someone else will need to confirm this.  By the way,  tell me how it goes as I need to do this too but I was waiting to do it when I do the TRT upgrade.
tkp
« Reply #2 on: 6 Apr 2003, 10:39 pm »
The red wire is + and the red wire with green stripe is -.  Looking at the pannel from the back where you solder the wire to the connectors and with the connectors in the top position, the right one is + and the left one is -.  Another way to locate the + post is that it is closer to the two eyelet sthat was used to solder the wire to for the stock ribbon pannel.
