0 Members and 1 Guest are viewing this topic. Read 2258 times.
Is there a reason, other than cost, that you wouldn't want to use 705 everywhere? The only difference between 703 and 705 is the density of the material, and thus the range of frequencies absorbed for a given thickness, correct? Or are you only looking to absorb the highest frequencies?
Well it's time to add some room treatments in a nondedicated room, also living room, and HT. From all the posts I've read lately, corner and first reflection points are the best places to treat. For each corner I plan to use a 2'x4'x3" piece of 703. I want to cut each piece in half the long way at a 45 degree angle, then cut the opposite side at 45 degrees the other way to give two 1'x4' wedges to go from floor to ceiling. I need some ideas on how to mount these. Would they be more effective spaced away fr ...
Thanks for the reply 8th. After reading about your new products, I assume adding the foil is to reflect the sound wave back into the foam. Would a couple layers of latex paint do the same thing?Thanks Ryan
