Quote from: ScottMayo Someone else would have to suggest casting for Brian Cheney; I want to stay on his good side. I say BC plays himself...as does the RM/X.... [/list:u]
Consensus is that angled walls do indeed alter the modes - and make them harder to calculate and control. It's easier to be able to predict them and deal with them if the space is simple, and you're going to have to deal with them no matter what you do, so it's better to keep it all straightforward.
I'm not sure what consensus that is, but with adequate angles between surfaces, modes can't exist. To me, straightfoward is eliminating problems by designing them away. Roof lines and vaulted ceilings have odd angles all the time, so the GC and drywall guys can do almost anything you can dream up. If you are building a house in a hot climate with huge picture windows, you don't put them facing west and then have to deal with all the cooling problems it creates. You change the design to eliminate the problem to begin with.
Appropriate shapes for room have been designed for a very long time before computers. They just don't fit very well into typical home floor plans. A separate structure, however, is another matter.
