Gentlemen,
I am overwhelmed by all of your responses.
Thank you all very much for taking the time to offer advice and outline your experiences.
Hugh: Thank you for your kind e-mail this morning. As stated in the fax, I was intending to confirm my order for the 100W N+ by e-mail but ended up spending the evening at the Vet’s with a sick cat...
(She is now much better by the way!) I was very interested to read your comments regarding JLH and Ben Duncan. I built my JLH amplifier from a ‘Hart’ kit shortly after the original article appeared in the August 1982 edition of Wireless World. (So it has lasted 23 years…not bad!) I had previously considered a Class A rig designed by Stan Curtis as detailed in Electronics Today International from July 1981 onwards. However, I wasn’t taken with his power amp design and only built the pre-amp. This in turn was replaced when Ben Duncan bought out his AMP-01 design in the May 1984 edition of Hi-Fi News. It is a funny old world. I built my first amplifier whilst at school in 1968 to a Practical Wireless Design. This used KT66s for the output, but what really created a buzz was the transistor input. I had to buy four OC71s which cost me (IIRC) two month’s pocket money. They were still in glass packages coated in black paint then. Remember scratching off the paint to produce photo-transistors?! Nowadays, the transistors are old hat and everybody gets off on the valves!
Peter: Many thanks for your critique of the N+ versus stock. I have subsequently ordered the N+ version. I was also very interested in your comments about active systems. I haven’t read any of Jens Thorson's postings, but have been considering Patrick Cazeles approach (
http://pcazeles.perso.cegetel.net/acxo.htm) for my ‘work in progress’ media centre.
EchiDna: My ART DI/O is still pretty much as shipped. I have done the usual output voltage divider mod but the rest was waiting for a suitable gap in the leisure hours. It’ll take even longer now!
Carl: My present ‘living room’ is 16’x12’ and the speakers are 10’ apart with the listening position at the apex of the triangle. For the UK, this size is pretty typical. I guess across the Pond you would call a room of this size a ‘walk-in closet’!
(A few years ago I was working in Reston VA for Cable & Wireless and I got invited back to a friend’s house to see his model railroad, my other great interest. It was in the basement which in itself seemed bigger than my house!) However, I am currently building my ‘retirement’ house in the French Pyrenees. The French builder thinks that I am mad as the living room size is dimensionally correct for Hi-Fi. I think he would be more understanding if the effort had been put into the master bedroom...
Occam: Glad to hear that you are still using your DI/O. With respect to the Speaker sensitivity, the Acoustic Research (AR) manual sheet is a little murky. It quotes ‘DIN’ sensitivity as being ‘8ohms’ with Sensitivity being “The number of Watts necessary to produce a sound pressure level of 96dB at the measuring microphone.” Elsewhere, Voltage Sensitivity is quoted as being “2.83volts produces 90dB SPL at 1 metre on axis.” Also, Efficiency is further quoted as being “1Watt produces 87dB SPL at 1 metre on axis”.
Rabbitz: Already a member of the ‘old farts club’ I’m afraid! I am getting more like Victor Mildrew every day. (Do you get ‘One foot in the grave’ in Oz?)
Malcolm, Seano, Jules, Chris and David: Many thanks for your valuable input.
Best regards to all,
Brian
